  #1
Old April 23rd, 2003, 09:59 PM
jathomps04 jathomps04 is offline
Default 80s Model Mercury 40hp 2 Cylinder 2 stroke cooling problem
I have recently aquired an older bass tracker with a 40 hp mercury 2 cylinder 80's model outboard engine on it. I have worked on it before and had it working but then the impeller went out. I replaced it and now with the new one in there is no water coming out the pee hole. I have double checked to make sure that there is nothing wrong with the lower unit assembly and everything looks good, including the impeller. What else can I check to find out why the water isn't exiting the pee hole. BTW, I have also checked to make sure the hole itself isnt clogged and it isnt.
  #2
Old April 24th, 2003, 03:58 PM
steelespike steelespike is offline
Default Re: 80s Model Mercury 40hp 2 Cylinder 2 stroke cooling problem
Be sure the water tube and grommets are in place. If the impeller crumbled pieces may have plugged the water galleries as well.
  #3
Old April 24th, 2003, 04:11 PM
Is there any specific way to check and clear anything that might be clogged?
  #4
Old April 24th, 2003, 04:26 PM
jim dozier jim dozier is offline
Remove the thermostat housing and thermostat and remove the lower unit. Back flush the system with a garden hose then forward flush it with the hose on the pickup tube that sets in the impeller. You should get flow both ways, if you don't you got a clog somewhere and it gets a little more dicey trying to figure out where. If you get good flow I would suspect something amiss in the water pump despite your best efforts to replace it.
  #5
Old April 25th, 2003, 07:49 AM
Thank you for your help. I got it fixed.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 40hp 4 stroke 3 Cylinder Alun Mercury & Mariner Outboards 6 September 3rd, 2006 08:30 AM
Mercury 40hp 4 stroke 3 Cylinder Alun Mercury & Mariner Outboards 1 August 22nd, 2006 09:30 AM
66 40hp Evinrude Model 40652B running on one cylinder Milford1971 Johnson & Evinrude Outboards 5 July 14th, 2006 06:08 PM
2001 40hp Mercury 2 stroke 2 cylinder Stall Robert Gregory Mercury & Mariner Outboards 1 July 3rd, 2006 05:12 PM
98 40hp Force Cooling Problem? tplatson Force & Chrysler Outboards 1 June 27th, 2005 08:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
