I've been getting some water in the lower unit.<br />It's not separating out but making the oil creamy.<br />Any best guess on where it's coming from?<br /><br /> thanks.
Pull it apart, reseal the unit and inspect the impellar while you're in there. Or you can make up an adapter, drain all oil and pressure test the lower unit while checking for air leaks.
