  #1
Old April 12th, 2003, 07:45 AM
r8rfan r8rfan is offline
Default reverse lock on mercury outboard
I recently bought an old bass tracker boat with a 40 horse mercury on it. A buddy of mine said that the motor is supposed to lock down when it is put in reverse. However when I do, it doesn't lock down. Could this just be an adjustment problem on the shaft or could it be that it's not hooked up in the lower unit? I figure if it's not working the motor will come up out of the water when I try and go in reverse. Any info would be greatly appreciated. Thanks a lot.
  #2
Old April 12th, 2003, 08:03 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: reverse lock on mercury outboard
If I remember correctly, There should be a pair of curved "Teeth", for lack of a better word, that clamp onto the transom bracket when put into reverse. Look under the motor at the bracket and have someone move the shift lever from forward to reverse and see if it engages.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old April 12th, 2003, 09:25 AM
Hey Rick, Yes the curved "teeth" are there, but when I put it in reverse while it's running they do not engage. Matter of fact I have looked at a parts list on the net and it seems that everything that is supposed to be there is there. Not sure why it's not engaging though. Thanks for your reply. I see you are from St. Louis. Ever get to the Lake of the Ozarks much?
  #4
Old April 12th, 2003, 10:51 AM
jamiei jamiei is offline
If someone changed the impeller or took the lower unit off, chances are they didn't pay attention to this shaft. There's a rod that has to fit inside the upper curved piece for it to work. Thats what happened to my merc 69' 500 (50hp) and I realized it when I changed my impeller... It's worth a try. If its a plastic unit, it may be worn out also and need replacement.
  #5
Old April 12th, 2003, 11:12 AM
Jamie is correct about the rod. I believe that it is possible to install it incorrectly and it will not function. Probably done when installing new pump. You will need to drop the lower unit and reposition it. And yes, I have been going to the lake for many years. Getting too busy out there for me though. Gonna try tablerock this year...
__________________
Rick
  #6
Old April 13th, 2003, 05:53 AM
Well I guess I need to drop the lower unit and see what is up. The guy I bought it from had changed the impeller last fall. Evidently he didn't get that put back in the right position. Is there a gasket where the lower unit drops down from the rest of the motor? I've taken a couple of other motors apart and don't remember if there was a gasket or not. Doesn't seem like there was. I've checked the lower unit oil and it's nice and clean. No water evidence. I almost hate to go into it, but it must be done! I've also noticed that the plugs have unburnt gas on them. Does this mean that she is not firing hot enough? Also does anyone know where I can find a parts list online for that motor? I've seen one before, but don't recall where it was at. It is a 1982 Mercury 40 horse thunderbolt ignition.Thanks a lot.
  #7
Old April 13th, 2003, 07:03 AM
jhreed jhreed is offline
Hey R8..., On my mercury, the mechanism was very stiff, as if the lubrication had gotten old and very dry... I physically moved the clawed teeth up and down (while in reverse of course) and the system loosened up and now works perfectly. Yes, I did get a heck of a surprise the first time I reversed also... We all learn from these little things, don't we? Jim Reed.
  #8
Old April 13th, 2003, 07:34 AM
Don't know your serial number, but this link is what you're after. There is no gasket on the lower unit mating surfaces. If your motor is running good, then your plugs may just be fouling at low speed. You could try leaning out the low speed mixture a bit at a time and see how it does. web page
__________________
Rick
  #9
Old April 13th, 2003, 02:38 PM
Thanks a lot guys. I got her fixed! There is a plastic cam at the bottom of the shaft that was put in backwards. Turned it around and it now locks down in reverse. Had to adjust the shaft quite a bit as the cam is worn,but the parts list that Rick gave the site for has the part I need.Thanks again for your help!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1967 Mercury 35 Reverse lock Ginder75 Mercury & Mariner Outboards 1 June 30th, 2006 12:16 PM
50 hp mercury will not lock down in reverse robertreed1973 Mercury & Mariner Outboards 3 April 17th, 2005 09:27 PM
Reverse lock system on 1980 20 HP Mercury JFNStuart Mercury & Mariner Outboards 1 June 8th, 2004 03:41 PM
reverse lock on 1976 Mercury 115 steve7107 Mercury & Mariner Outboards 1 March 12th, 2003 03:36 PM
reverse lock on Mercury 35 manual tilt mikedaly Mercury & Mariner Outboards 3 August 12th, 2001 09:07 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
