  #1
Old April 4th, 2003, 08:59 AM
canbey canbey is offline
Default cooling problem for mariner
i have a 1996 mariner 15h.p...the water comimg from the telltale hole comes and goes at any speed.had a new pump and thermostat installed with no success.the mechanic said this was a factory mistake but no answer how to fix it.can any one please help this is driving me crazy...thank you canbey
  #2
Old April 4th, 2003, 09:58 AM
graddy graddy is offline
Default Re: cooling problem for mariner
There is a small passage way around the thermo that should let water out the tele tale to give you indication that the there is water going through the block. The only other place water could be escaping is from the P/H base gasket. Did you replace only the thermos or did you replace the housing also, that passage way could be clogged with debri.
  #3
Old April 4th, 2003, 10:06 AM
thank you ...i am going to check with the mechanic now , will post the results thank you
  #4
Old April 4th, 2003, 10:12 AM
the mechanic said it was clean and smooth as silk inside,he cant figure it out either..
  #5
Old April 4th, 2003, 10:42 AM
I would not worrie about it then, your mechanic is correct. Just make sure the engine is not overheating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
70HP Mariner (1979?) Cooling Jacket Greghux Mercury & Mariner Outboards 2 March 13th, 2005 01:13 PM
15hp mariner cooling meh Mercury & Mariner Outboards 1 September 27th, 2004 09:28 PM
no water cooling mariner 4 hp jmbazille Mercury & Mariner Outboards 0 July 14th, 2004 02:33 PM
Mariner 15 cooling question gittygoat Mercury & Mariner Outboards 1 August 23rd, 2003 12:03 AM
mariner 30hp cooling mrfixit_59 Mercury & Mariner Outboards 0 June 21st, 2003 07:19 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
