  #1
Old April 2nd, 2003, 11:26 AM
chrismercury chrismercury is offline
Default 1970 mercury 650 fuel pump 1 or 2 ?
Does anyone know if a 1970 mercury 650 4 cyloutboard needs 1 or 2 fuel pumps? I bought this motor with only an upper fuel pump, it runs to the upper carb then from there to the lower carbis this how it's suposed to be. Or do I have to put the lower fuel pump on, and run it to the lower carb??? thanks for any help
  #2
Old April 2nd, 2003, 11:36 AM
mellowyellow mellowyellow is offline
Default Re: 1970 mercury 650 fuel pump 1 or 2 ?
welcome aboard,pretty sure they came from merc with 2 pumps.can tell you my inline 6cyl '70 1150 has 3.mounted on right side of block from behind.have heard of folks adding an extra electricpump to them... the factory pump works off ofinternal pressure. maybe this is what yur seeing?good luck,M.Y.
  #3
Old April 2nd, 2003, 11:53 AM
thanks for the info
  #4
Old April 2nd, 2003, 01:15 PM
you'd be surprised how many of these old girls arestill running... click on "search" link above andthere's hours of reading about them on specificquestions. if'n you don't already have a servicemanual, get one! they are great motors but theyrequire good maint. there's a link below formanuals, or at local library for free perhaps?thirsty motors, so start with fuel starvation.good luck!M.Y.
  #5
Old April 7th, 2003, 02:49 PM
Gold Bear Gold Bear is offline
chrismercuryNot trying to start any trouble here... I used to have a 1972 50 horse and I'm sure it had only one fuel pump.Also, my 1971 115 horse has two fuel pumps. There is a "boss" on the side of the block for a third, but it has only two pumps.Are you having any problems with the way the eingine is running?Good Luck,Gold Bear
  #6
Old April 7th, 2003, 04:38 PM
I only heard it run for a second when I bought it. I tried to start it but it just turned but wouldn't start or even try to.not sure what a "boss" is, but there is a place under the upper fuel pump that looks like you could put a fuel pump just like the upper one.
  #7
Old April 8th, 2003, 09:29 AM
chrismercury That is a "boss". I believe my old 50 horse was the same way - one fuel pump and an extra "boss".If you find she is not getting fuel, it is simple to change the fuel pump diaphram.Check for fuel, spark, timing, and compression. You may have to re-build the carbs etc.Do a search for trouble shooting on this board and I'm sure you can get the old girl running.Good Luck,Gold Bear
  #8
Old April 8th, 2003, 02:54 PM
Thanks, I already bought a kit to rebuild the fuel pump,I'll get the carb kits and do it all at the same time.Thanks for the help
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
NEED FUEL PUMP FOR 96 225 MERCURY ukcatsgrace Mercury & Mariner Outboards 2 July 23rd, 2005 02:18 AM
115 hp Mercury fuel pump golfgod7 Johnson & Evinrude Outboards 0 August 5th, 2004 08:56 AM
mercury 115 fuel pump i610288 Mercury & Mariner Outboards 2 September 25th, 2003 06:48 AM
'68 mercury 110, 9.8 fuel pump ? LanceM Mercury & Mariner Outboards 2 July 14th, 2003 03:40 PM
fuel pump on 65 hp. mercury mrmarvc Mercury & Mariner Outboards 5 January 13th, 2003 03:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
