  #1
Old April 1st, 2003, 07:56 PM
y2jericho y2jericho is offline
Default Mercury Thunderbolt 650cc 65hp 1970 has a water leak ;(
My motor is leaking water around from where the block bolts onto the shaft. It seems to me that maybe just the seal is leaking because its old and because of this water is seeping out on the side around the blocks. But at high speed this becomes a spray so the sale water is corrodoing my spark plugs ;( and possibly grounding them causing missfire...I bought another motor exactly the same without a lower unit but is unfortunately a short shaft so i can't just put the LU on and start using it.. The block in it has compression of 120-130 around all cylinders so its fairly good and plus i have all the other parts i could ever need like carbs, power packs, distributors etc.. This block currently in my motor is about 95-105 compression so it is fairly old and when it reaches about compression of 85 over the cylinders i will start putting the blcok from my newer motor onto this one.My question is.. Why does the shaft/head leak water all into my case so theres more water coming out of the case than the peehole.Currently i have gotten some epoxy glue (very heat resistant and strong) and sealed all around the block about 1-2mm thick where the seal is but it still leaks hte tiniest amount...Is there any way i can fix this without removing the block and is it a matter of the blcok being screwed or can u fix it with new seals? Because soon or later im going to have to port the other block onto this one and i know the other one doesn't leak but any precautions should i take? I heard also it might be corrosion eating the seal and aluminium away from ****heads that don't flush there motor properly (i always run for at least 10 minutes after a trip)Thanks in advance iboat users
  #2
Old April 2nd, 2003, 02:13 AM
Default Re: Mercury Thunderbolt 650cc 65hp 1970 has a water leak ;(
anyone Ill have pics up soon of my completed fibreglass money hole
  #3
Old April 2nd, 2003, 04:37 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
It's really not a big deal to pull the powerhead off and do it the right way, rather than trying to apply a band-aid. In all likelyhood, you've got a blown out gasket, which isn't too hard to replace. It might also be indicative of a bigger problem, one which patching won't fix. You might have a blockage somewhere in the cooling system which is preventing water from entering or exiting properly, in which case pulling the powerhead would likely allow you to see the problem and correct it.Start by pulling any wires/hoses that connect the belly pan to the powerhead - marking them if you're unsure about how to reconnect them. Take pictures, etc. Remove the lower cowling to expose the powerhead retainer nuts - there should be eight. Invite over a big friend to help lift the powerhead - bribe with beer if necessary. If no big friends available, try a come-along looped over a garage rafter. Work carefully and methodically and you'll get it done... might take a long afternoon to complete it...- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water leak from Powerhead Area Mercury 650 Thunderbolt 1970 redband chewbacca Mercury & Mariner Outboards 10 September 17th, 2003 03:00 PM
Goes into reverse on land but not into reverse on water.. Mercury 1970 650cc Thu y2jericho Mercury & Mariner Outboards 5 May 12th, 2003 03:54 AM
Motor and boat question. Mercury 650cc 1970 4 cyl 65hp y2jericho Mercury & Mariner Outboards 2 April 19th, 2003 12:29 AM
Another Dumb Question.. Mercury 650cc 65hp 1970 Thunderbolt Question y2jericho Mercury & Mariner Outboards 2 March 31st, 2003 02:47 AM
1970 Mercury Thunderbolt 650cc 65hp 4 cylinder is it really 65hp? y2jericho Mercury & Mariner Outboards 3 December 10th, 2002 09:40 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
