I have a 1999 135hp merc on a 21' zodiak that stalls when i bring it up. It stalls at arround<br /> 1500-<br /> 1800 rpm this is the second engine that has same problems. if you squeez the priming bulb<br /> when it starts to stall it climbes through the bad spot and achives full power. since its the<br /> second <br /> engine and the same boat I assumed that it had to be something in common i.e. the fuel sys. I<br /> belive<br /> that I have checked everything, pick up tube, anti siphon valve, new fuel lines,fuel filters,priming<br /> bulb,<br /> and I ran it strait from a 5 gal can to no avail.
