  #1
Old March 20th, 2003, 03:29 AM
newbowhunk newbowhunk is offline
Default 30 Hp Mariner WILL NOT START FROM KEY.....
I just bought this boat. The motor will start up fine with the manuel rope. Tried to start it from the key and nothing. I then got the multimeter out. I check the solenoid and it had 12 V on it with the key pulled out. I shouldn't have power there with the key out right. Also there is and in-line fuse in the that blows everytime i put a new one in there. Anyone help me out..................Thanks
  #2
Old March 20th, 2003, 04:03 AM
ICEMAN ICEMAN is offline
Default Re: 30 Hp Mariner WILL NOT START FROM KEY.....
Hi, I would agree the solenoid should not have current with the key out. Sounds like you have a short in the ignition switch or wiring to the switch, that's why it's blowing the fuse.
  #3
Old March 20th, 2003, 04:05 AM
Hi again, here's another thought, Check to make sure the battery wires are connected to the correct terminals on the battery. If they are backwards, the fuse will blow and you may have power showing at the solenoid.
  #4
Old March 20th, 2003, 06:32 AM
Walker Walker is offline
The battery side post on the solinoid doea indeed have 12v to it even with the key off. The starter post shouldn't have any charge until you hit the start position with the key.
  #5
Old March 20th, 2003, 07:00 AM
I guess I should slow down and read the post a little better. Walker is correct, one side of solenoid will have current, since the positive battery cable connects to the solenoid. When I read the post, I assumed (shouldn't do that) You meant there was current on both sides of the solenoid. I should have have asked if there was, when the key was out.
  #6
Old March 20th, 2003, 07:44 AM
I'm thinking that i may have the battery cables on the battery backwards cause the guy I bought the boat from said that the key would start it. But the battery was dead when i got it. Charged it up and put it in lastnight in the dark with a flashlight. I will check to make sure battery wires or correct. ** If this helps yall out whenever i turn the key to start the motor there is no clicking like the solenoid is closing the contacts to send power to the starter. Another thing that is wrong is the starter the bendex<-- is not moving up to turn motor over. Bendex will move up by hand just not when you bypass the solenoid. Thanks for the help...........
  #7
Old March 20th, 2003, 08:34 AM
NathanY NathanY is offline
Silly question here, Is the battery fully charged? You said that it starts just fine with a rope, you also said that you were able to move the starter, but you were not able to jump it and make the starter turn. Sounds like you have a dead Or bad battery .
  #8
Old March 20th, 2003, 08:36 AM
Yes the battery is charged has 12V on it. Can make the starter turn by bypassing solenoid with a srewdriver. When i do that the starter turn but the dendex does not come up.........
  #9
Old March 20th, 2003, 09:05 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
JNF Try a different battery using jumper cables connected. One to ground and hot directly to the starter terminal. Let us know what happens
__________________
Rick
"Boating is Life...All the rest is just Details"
  #10
Old March 20th, 2003, 09:48 AM
Check this out I left this part out. With the battery hook up the way i have it the bilge and aireator still comes on could this work with it hook up backwqards.......
  #11
Old March 20th, 2003, 10:06 AM
What i'm saying is i'm leaning towards it being the battery cable on the battery backwards. But i remember the bilge and aireator working. But i'm sure with the battery cables backwards the bilge and aireator would work but would not work properly. Also with that fuse blowing on the motor this sounds logical. Who knows...Hope this help yall out......
  #12
Old March 20th, 2003, 10:07 AM
  #13
Old March 20th, 2003, 11:15 AM
The aerator and bilge pump will work with the battery hooked up backwards, but they will also spin backwards.
  #14
Old March 20th, 2003, 11:22 AM
JNF Can you hook up the battery correctly and see what happens? That would be the first step.
__________________
Rick
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
85 Mariner Electric Start tobystan_2000 Mercury & Mariner Outboards 5 September 28th, 2006 07:11 PM
mariner 225 efi will not start aaoliver Mercury & Mariner Outboards 13 September 8th, 2005 07:56 AM
MARINER 150 EFI WON'T START JCARROLL Mercury & Mariner Outboards 1 October 3rd, 2004 12:48 PM
mariner 90 non start atlantic Mercury & Mariner Outboards 1 June 3rd, 2004 04:37 AM
Mariner 25 doesn't start when hot ernie6283 Mercury & Mariner Outboards 0 July 14th, 2003 07:15 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
