March 17th, 2003, 12:03 PM
Stripping oil pump drive gear on Mercury EFI
I am looking for a fix for Mercury 150EFI (1998) oil injection pump gear located on the crankshaft (its plastic). This gear keeps stripping.
March 17th, 2003, 12:18 PM
Re: Stripping oil pump drive gear on Mercury EFI
Is it possible to remove the oiler and rn premix on an EFI motor? If so that might be one option.
March 17th, 2003, 12:37 PM
TTRapid
There is a steel gear available. It is recommended for a lot of high speed running. Those gears were known to fail and I believe at one time there was talk of a recall. Give the dealer a call and see if they have one or can get one.
__________________
Rick
"Boating is Life...All the rest is just Details"
March 17th, 2003, 03:37 PM
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Rapair / CDI markets a trick little replacement deal that no longer relies on the gear. It's a very nice looking unit.
Good luck!
March 17th, 2003, 03:55 PM
just curious, how many times has this failure been repaired?
March 18th, 2003, 02:43 AM
MERTECH, I have dad this failure twice in the last 2 years and it's getting me pissed off.
March 18th, 2003, 02:48 AM
Dhadley, how do I get infomation on the mod you mentioned. Rapair/CDI.
March 18th, 2003, 03:28 AM
Call Clark Beard or TJ at 256-772-3829.
Good luck!
March 18th, 2003, 05:11 AM
The plastic gears are for Mercury's recommende rpm range,less than 6000 rpm and strip easily. I have some friends that turn over 10000 rpm. Take the oil pump off and replace it with a block off plug that you can get from Mercury. Then mix your own oil/gas. If you continue to run the gear you will have a major melt down
Dave
March 18th, 2003, 08:25 PM
Just removed the oil pump from a pair or 200 Merc I bought,1 seized due to broke oil tube( they get brittle)Put plug in like mentioned.My motto on oil injection " it's not if it's going to fail,it's when". I like my motors.
March 19th, 2003, 06:05 PM
Call API Marine 800-327-6086 for information on Marine Solution's Electronic Oil Injection system.
March 24th, 2003, 02:51 PM
I installed an electronic oil injection system from G FOrce Technologies today. It works great and not to differcult to install.
Thanks
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
