tundrarules
- May 7, 2002
- 3
Let me first say thanks to you all for taking the time to share all your knowledge on this forum. <br /> 40HP Mariner<br />40ELTO<br />Serial #6E9 L 502961<br />Carb. 6E901/CA07<br />Carb. rebuilt kit part # 17068m<br />The engine was stalling when put under a load. Rebuilt carb. as first step in trouble shooting. When I pump up the primer bulb fuel pours out of the carb. I don't understand what is going on. I swapped the seat and valve on both carbs and it is still doing the same thing. I put it back together exactly like it came apart. Only thing I can think of is that the parts are not the right ones for this carb. I called to varify the part # for this carb. and it checked out. I am so frustrated. To make things worse I tossed all my original parts. I know better than that!!Never throw away anything until everything is running!!!!!!!!!!. Thanks guys. I hope you have an answer for me. It may be the fuel pump, but I don't think so. What else would keep the fuel from running from the main jet besides the float and needle valve?
