  #1
Old March 9th, 2003, 08:51 PM
takidd4597 takidd4597 is offline
Default mariner alarm
I have an overheat alarm going off but have great tell-tale flow. I can keep my hand in the stream forever.I have a small nut with a wire next t o the 1st spark plug on the top can anyone tell me if this is what it is: 87- 96829A 1 TEMPERATURE SWITCH ASSEMBLY (260 DEGREES) 1 $69.20 Also do these go bad or what can I do to fix it or what?It is on a 1988 marinew 60hp motor. Mercury parts express has a different part for the cylinder head that is:38 12415 TEMPERATURE SENDER (POWERBOAT) 1 $15.50 39 84- 88824A 7 CABLE ASSEMBLY (POWERBOAT) 1 $22.30 I don't seem to have one of these on mine and have a feeling that it goes lower on the head where I have a plug(bolt). How would this work and what else woulds I need for this instead of the switch. Web page etc would help also what temp should I be at?
  #2
Old March 10th, 2003, 02:40 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: mariner alarm
takidd4597You are talking about 2 different things. What you need is the temperture Sensor(Temp. Switch Assem.) which sounds the alarm when the engine is overheating. The other part that you refer to are temperture sending units, which would be used with a remote gauge to moniter your temp. The sensors do fail on those motors causing a false alarm. When the alarm sounds, disconnect the wire from the sensor and see if it stops. Your motor should run about 140 degrees. You can check this with a thermomelt stick available at the dealer, which determines the temp. of the cylinder head, to check if you are indeed overheating or if the switch is causing the problem. If the alarm goes off before the mark you made with the stick melts, then you have a faulty switch.
__________________
Rick
"Boating is Life...All the rest is just Details"
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
150 Mariner alarm skiking Mercury & Mariner Outboards 2 July 29th, 2007 10:52 PM
alarm on mariner 100 ronuncw Mercury & Mariner Outboards 1 August 26th, 2004 04:44 PM
Mariner 60 h.p. Alarm oldironman57 Mercury & Mariner Outboards 4 August 3rd, 2004 07:58 PM
40 elc Mariner alarm lundlander Mercury & Mariner Outboards 0 April 26th, 2004 09:00 AM
Mariner alarm takidd4597 Mercury & Mariner Outboards 2 March 1st, 2003 03:42 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
