  #1
Old March 5th, 2003, 04:26 PM
ranger115blue ranger115blue is offline
Default 1979 115 Horse Mercury Gear Case Prop Shaft Nut
My lower unit was leaking. I found out that is is crack. It is a 1979 Mercury 115 Outboard, I also have a 1965 65 Hp Mercury Outboard the gear cases look identical. Would these interchange. I would have to change the prop shaft and gears because the reverse is out of the 65 horse. I removed the first prop shaft retainer nut, I remove the square retainer pin but I broke the 1/2 drive ratchet trying to remove the prop shaft retainer nut. Could I weld the cracked gear case and it be strong enough? it is cracked from the drain plug around the front of the gear case and down the other side. Thanks for any help, Terry
  #2
Old March 5th, 2003, 05:15 PM
alcan alcan is offline
Default Re: 1979 115 Horse Mercury Gear Case Prop Shaft Nut
Hi Ranger If you keep all your questions and responces on the same topic we won't have to chase you down. This will give you better help. I misunderstood your last question. Your 65hp L/U will not swap with the 115. If you could post the ser# of the 115 it will help. As far as I can tell there is just the one gearcase cover nut. Behind that is the bearing carrier. It's real hard to determine the severity of your crack sitting here. It doesn't sound very hopefull. A good welder can work miracles, it doesn't hurt to ask. I think I would look for another L/U. From your description I think you would be money ahead. You my be able to sell some of the parts to help offset the cost of replacement.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Space between new prop and gear case Joe Bush Prop Questions and Topics 3 June 24th, 2006 12:20 PM
Prop rubs gear case! caisson1 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 October 25th, 2005 04:35 AM
1983 mercury 70 hp gear case removal rodger c Non-Repair Outboard Discussions 1 March 14th, 2004 09:21 AM
1983 mercury 70 hp gear case removal rodger c Mercury & Mariner Outboards 1 March 14th, 2004 09:21 AM
Evinrude 15 HP 1979 How Do I Remove Gear Case RasmBTop Johnson & Evinrude Outboards 3 July 20th, 2002 08:51 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
