On the stator plate there are three coils, as far as I know these are
One for auxiliary power supply to a radio etc.
One radially orientated for ignition
One circumferentially orientated for ignition.
There was a problem with the circumferentially orientated coil and so I rewound it with almost identical wire and turns etc.
Connections on this coil are one to ground (under the metal laminates) and one to a brown wire from the ignition.
Well I've done all this but there is not a peep from the engine,
Would it make a different if this coil is wired in the wrong way round???? i.e. have I 'grounded' the wrong wire?!
Could this be the source of my problem???
ALL help much appreciated,
Thanks
matt
