  #1
Old January 12th, 2003, 05:46 PM
mrmarvc mrmarvc is offline
Default fuel pump on 65 hp. mercury
I was reading some of the posts on retrofitting some motors to a fuel pump. I suspect the original pump on my '65 merc. 65 h.p. is weak, and was wondering if anyone has any insight to putting on some kind of new pump, electric or otherwise, on it and get good results. Right now the setup is one hose from tank through a primer bulb to a small pump (approxitely 1 1/2" square and 1/2 or 3/4" thick), then to the carbs. Is that the pump, and can it be relpaced with say an electric fuel pump like from a car? Any suggestions?
  #2
Old January 13th, 2003, 11:38 AM
snapperbait's Avatar
snapperbait snapperbait is offline
Default Re: fuel pump on 65 hp. mercury
Yes, that is the pump... If your pump is ailing why not repair it?... It's very simple to repair, if the parts are avalible...After looking around a bit on the web for a fuel pump repair kit for your 65' I see why you might be in need of a fuel pump as repair kits do not seem to be readily avalible for a motor of that vintage.... Electric fuel pumps If you go with an electric pump (which I do not advise BTW), try to find one with low pressure (4psi or less) but high volume and it needs to be a "MARINE" pump because of safty issues...
__________________
Now understand, Commander...
That torpedo did not self destruct...
You heard it hit the hull...
And I...Was never here...
  #3
Old January 13th, 2003, 11:47 AM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Marv,don't know if this will help you, but NAPA auto parts catalog has the fuel pump kit listed as: part # 18-7807 for a 3 Cyl 65 HP.Part # 18-7804 for serial numbers between:1542754-2803561 65HP
__________________
Rick
"Boating is Life...All the rest is just Details"
  #4
Old January 13th, 2003, 11:53 AM
This site may also help: web page
__________________
Rick
  #5
Old January 13th, 2003, 01:13 PM
steelespike steelespike is offline
Marvc,Your pump should work fine with a rebuild.Be sure the system is sound,all connections andconnectors working right.Not sucking air etc. Check that tank vent.Sometimes the pump pulse port will get restricted causing it to be weak. Check with the guys at Johns Old Mercury Web Site at:www.pfs-ware.com or Grubbs Marineat: www.oldmercs.com.Grubbs specializes in repair and restoration of old mercs and I believe they have parts too. Johns site has a good forum and lots of links.
  #6
Old January 13th, 2003, 03:52 PM
Thanks so much snapperbait, ricjdb1boat, and everyone for your very helpful info and web sites. I will also check out my local napa store for help also. For the price i found on the website, I'll try to just order from them if possible, and parts are available for my year. Your right, there is not much to these pumps, so can do it myself. I do suspect it may be sucking airin somewhere in the fuel system,probably between the pump and carbs as I put on all new line from front of motor to tank. Also cleaned tank good first. I still need to get a spark tester and new plug wires, but that is going to be a while off as it's too cold to be messing on it now. Thanks again
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
NEED FUEL PUMP FOR 96 225 MERCURY ukcatsgrace Mercury & Mariner Outboards 2 July 23rd, 2005 02:18 AM
115 hp Mercury fuel pump golfgod7 Johnson & Evinrude Outboards 0 August 5th, 2004 08:56 AM
mercury 115 fuel pump i610288 Mercury & Mariner Outboards 2 September 25th, 2003 06:48 AM
'68 mercury 110, 9.8 fuel pump ? LanceM Mercury & Mariner Outboards 2 July 14th, 2003 03:40 PM
140 mercury weak fuel pump VMAX Mercury & Mariner Outboards 2 August 5th, 2002 06:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
