  #1
Old December 15th, 2002, 03:02 PM
lake_time_2 lake_time_2 is offline
Default how to remove the oil injection on a 90hp mariner?
I want to remove the oil injection on my 1989 90HP(i think serial number OC136657) mariner?) and run just pre-mix?Can i just disconnect the oil pip that goes to the fuel pump and cap it? Or is there more to this that that? I was thinking of routing the pipe from the pump back to the oil tank to it continue to circulate oil in a loop. Any thoughts suggestion or words of advice?Also what ratio should I run? The motor is on a 18 foot center console that is used for fishing and has separate trolling motor if that helps any.Thanks as always.. Dave
  #2
Old December 15th, 2002, 03:53 PM
rickdb1boat's Avatar
rickdb1boat rickdb1boat is offline
Default Re: how to remove the oil injection on a 90hp mariner?
From a previous post:First, disconnect the oil line from the motor and securely cap the fitting - you don't want dirt, water or other contaminants getting in there and gumming up the operation at a later date. Next find the wire harness coming off the back of the pump and unplug the amphenol connector (black rubber, about 3/4" in diameter, about 2" long and 3 or 4 wires depending on age). Trace the 2 wires from the tank to where they connect at the motor, disconnect and remove the wires from under the hood. Tape off the wires remaining on the engine harness and then you can remove the oil tank from the boat. And lastly, remember to premix at 50:1 - you won't get a 2nd chance if you forget.
__________________
Rick
"Boating is Life...All the rest is just Details"
  #3
Old December 15th, 2002, 04:25 PM
YOU SO ROCK!!!! Thanks rickdb1boat This sounds like it should be easy.. I'll let you know how it goes.. Thanks again.. Dave
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
remove iol injection jze1212 Yamaha & Suzuki Outboards 4 February 23rd, 2006 07:31 AM
Oil injection - Keep or Remove dtherrien Mercury & Mariner Outboards 7 August 25th, 2005 03:48 PM
how to remove my oil injection...? phatmanmike Mercury & Mariner Outboards 2 October 11th, 2004 06:33 PM
Remove oil injection or not?? Hasbeen Mercury & Mariner Outboards 9 September 22nd, 2003 05:44 PM
Remove oil injection macojoe Yamaha & Suzuki Outboards 3 May 2nd, 2003 09:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
