  #1
Old December 14th, 2002, 08:19 PM
KIRASIR KIRASIR is offline
Default Mercury idle speed and temperature gauge
1. I recent bought a boat with an 80hp 1980 Mercury motor. I haven't tried it in the water yet, but when I ran it on muffs it was idling at ~1900-2000RPM. Any idea what the idle speed should be for this motor? (It starts right away without any hesitation.)2. I also want to add a water temperature gauge. There is a plug at the end of the block called "block flush plug" (I think). Can I take it out and screw the temperature sensor instead?(see the pictures) plug and sensor plug Thanks guys.Serge
  #2
Old December 15th, 2002, 07:07 AM
Rex Rex is offline
Default Re: Mercury idle speed and temperature gauge
iF YOU WOULD THINK ABOUT SELLING IT LET ME KNOW.tHANK yOU
  #3
Old December 15th, 2002, 07:53 AM
snapperbait's Avatar
snapperbait snapperbait is offline
Idle RPM in forward gear should be approx. 700 RPM... In neutral arrorx 800 RPM... My Merc 60 Idles high (1500) on the first cold start for about a minute then it settles to 800-850...If the idle does not come down after warm up, then an adjustment is necessary... Check all the linkage and make sure the carbs are fully closing and opening in sinc...For the temp sensor, If the area behind the block flush plug is deep enough to accept the sender then go for it...
__________________
Now understand, Commander...
That torpedo did not self destruct...
You heard it hit the hull...
And I...Was never here...
  #4
Old December 15th, 2002, 10:40 AM
snapperbait:When I start it up it idles at about 1900 but I never ran it long enough to let it completely warm up. I guess I'll know in the spring. ThanksSerge
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Riser Temperature at idle speed VisionIsle Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 March 7th, 2007 03:09 AM
mercury/mariner 40 hp idle speed marquette Mercury & Mariner Outboards 1 May 3rd, 2006 03:18 PM
1994 Mercury 150 v6 black max temperature gauge not working McFish Mercury & Mariner Outboards 4 May 3rd, 2006 01:59 PM
Mercury 7.5 runs only at idle speed btouch Mercury & Mariner Outboards 3 May 12th, 2003 08:12 PM
MERCURY IDLE SPEED billw Mercury & Mariner Outboards 3 November 9th, 2001 08:54 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
