  #1
Old November 10th, 2002, 01:51 AM
snooks2005 snooks2005 is offline
Default HELP w/1998 Mariner 50 4 stroke Big Foot Lower Unit
I currently have a 1998 Mariner 50 4 Stroke Big Foot with a 2.31:1 lower unit and would like to change to the standard lower unit with 1.83:1 or the 2:1 lower unit. Does anyone know what model year lower would bolt up to my current engine. thanks
  #2
Old November 12th, 2002, 06:09 PM
Default Re: HELP w/1998 Mariner 50 4 stroke Big Foot Lower Unit
anyone?
  #3
Old November 12th, 2002, 08:31 PM
ob ob is offline
Snooks,I smell a need for more speed.Don't think motor will perform any better as these puppies are engineered to operate with the ratios provided .Best thing you can do is play around with prop pitches.
  #4
Old November 12th, 2002, 11:08 PM
orca orca is offline
G'Day. I think that you the Merc 50 BF 4 Stroke uses a differant crankshaft to the standard model as the driveshaft uses differant splines, could be wrong though, I will check.
  #5
Old November 13th, 2002, 01:38 PM
Thanks guys...ob yes you do smell a need for more speed. But I have tried just about every prop that exists for this motor for the application I am using it for which is on a flats boat.whaley I would appreciate if you would check into for me
  #6
Old November 13th, 2002, 01:43 PM
ob ob is offline
Snooks , What rpm are you able to attain at WOT in relation to what the motors recommended WOT range is?Is motor mounted at optimal height(as high as you can get it) on transom without cavitation?
  #7
Old November 13th, 2002, 02:45 PM
forgetaboutit forgetaboutit is offline
Buy a bigger motor if you want to go faster.
  #8
Old November 13th, 2002, 02:56 PM
ob thanks for your time.ob currently I am getting 5450 with a power tech 13 3/4 x 15 3 blade SCD model prop and as I raise the jackplate I can get alittle more rpm to about 5600 but after that the prop starts to slip and then it blows out. I am getting about 32 mph with this prop. I also have a power tech 12 3/4 x 12 XSB model 4 blade prop which I can raise a full five inches on the jackplate and get maybe 5500 rpm at about 5 inches of lift but nothing changes once I reach about 3 - 3 1/2 inches of lift in either the rpm range or speed range. With this prop I am getting about 29 mph.
  #9
Old November 13th, 2002, 02:59 PM
mr. forgetaboutit....thank you for your informative response...If I could sell my current engine I would not hesitate to repower.
  #10
Old November 13th, 2002, 03:04 PM
ob ob is offline
Sounds like you've got your propping and motor height under control .Only thing that would concern me ,and I'm sure you, is that changing gear ratios to closer tolerance will obviously put more strain on motor,particularly out of hole performance.In theory it would go faster, but I'm not sure if your motor will have the juevos to get it there.Sort of like increasing prop pitch.
  #11
Old November 13th, 2002, 03:11 PM
I forgot to mention that my wot should be 6000 rpm
  #12
Old November 13th, 2002, 03:16 PM
ob ob is offline
What's the lenghth and approx weight of boat?
  #13
Old November 13th, 2002, 03:19 PM
16' flats boat weighs about 900lbs
  #14
Old November 13th, 2002, 03:35 PM
ob ob is offline
Snooks,that is a relatively heavy rig.Don't know what your added gear weighs,but here is a comparison example.I run a 15ft whaler that weighs 850 lbs. pushed with a 95 70 hp. rude at 6000+ with a 131/4 x17 omc prop and get 42 mph.That four stroke your running also likely is heavier than it's 2 stroke counterpart and when you match a relatively low hp to boat weight ratio every pound begins to have a significant effect on performance.In short it would be my guess,and just that,my guess ,that changing gear sets in lower unit would be an excersize in futility,not to mention the cost.
  #15
Old November 13th, 2002, 03:40 PM
well the boat weighs about 500 lbs the 50 four stroke weighs 228 lbs, the jackplate weighs 37 lbs and I also have a 20 gallon fuel tank in the bow.
  #16
Old November 13th, 2002, 03:45 PM
ob ob is offline
That changes things a bit.Off hand it sure seems that motor would rap further than 5400 trimmed out with a 15" pitch prop.
  #17
Old November 13th, 2002, 03:48 PM
oh I forgot to mention also that it porpoises when the jackplate is raised also.
  #18
Old November 13th, 2002, 03:52 PM
ob ob is offline
Even if motor is trimmed in all the way?
  #19
Old November 13th, 2002, 03:56 PM
no just when I have trimmed out the boat and have started to raise the jackplate is starts to porpoise.
  #20
Old November 13th, 2002, 04:00 PM
ob ob is offline
Sounds ok as long as you can adjust it out.Man Snooks ,I am fresh out of ideas besides a good motor tuneup for your rig.
  #21
Old November 13th, 2002, 04:02 PM
yeah everybody seems to be out of ideas what tuneups would you suggest?
  #22
Old November 13th, 2002, 06:40 PM
BillP BillP is offline
Location: Recently moved to high rise waterfront condo on Pluto. What a view!
Two suggestions...reduce the prop diameter and use a 4 blade prop on jackplates...pitch way up if you are mostly running with the jackplate up. Put a Doelfin on it. The Doelfin let me get approx 5 mph faster just by letting me trim higher...expecially so if you are using a 3 blade. Don't forget the low water pickup and presure gage when getting this high.
  #23
Old November 14th, 2002, 07:05 AM
BillP.....I have already tried the smallest diameter 4 bladed prop that power tech makes which is a 12 3/4 x 12 pitch. So what you are saying is to have the diameter of this prop reduced?
  #24
Old November 14th, 2002, 03:09 PM
You need less diameter and lots more pitch to make approx 6000 at full throttle while jacked up. If you can't find a stock 4 blade look for a 3 and size for around maybe 18 pitch. This stuff is really trial and error. Math only gets you to the starting gate. Your 3 blade may be much better if you try the Doelfin...I would do that before anything else. The one I added made a whopping big difference at top end. It reduced cavitation/ventillation a huge amount when trimmed up. You have another 400 rpms to play with...presuming the max is 6000? I currently have a Mariner 50 4s with 2:0 gearcase and the max is 6000...3 blade propped at 5600 on a 20' pontoon.I ran in a hardcore flats boat that was pitched at 27 (yes 27)on a 4 blade. This one had a 175 Merc and all the go fast goodies for shallow running. It literally screwed through soft bottom in ankle deep water at 45mph with 2 up...it ran 65 in clean water. It was a 20 "Crossover" (650lbs kevlar)and made in your neck of the woods.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1998 mariner 40hp 2 stroke framarjen 3 Mercury & Mariner Outboards 3 September 4th, 2006 10:57 AM
Mariner 115 HP 1998 carbuerated 2 stroke keeps bogging out pasquale1968 Mercury & Mariner Outboards 9 February 5th, 2006 12:10 PM
1998 Mariner 30 hp lower unit repair Raybiz Mercury & Mariner Outboards 4 July 25th, 2003 07:51 PM
1998 Mariner 200 HP 2.5 Liter Lower Unit Alignment bruss4438 Mercury & Mariner Outboards 1 July 18th, 2003 08:43 AM
1998 25 HP Mariner 4 Stroke...Any Good? Newhook Mercury & Mariner Outboards 3 February 20th, 2002 02:57 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
