  #1
Old November 5th, 2002, 07:14 PM
CaptRonR CaptRonR is offline
Default 1999 175 Mercury SportJet stalls when idling
My 1999 175 Mercury SportJet was running fine up until the last time out on the river. Engine started fine and ran good at high speed but after shutting off the engine for a while to fish. It was hard starting and kept stalling after starting and leaving in idle. Replaced the anti-siphon valve, fuel filters and tightened all the clamps on the fuel lines.Engine will idle while it is cold but after it is warm stalls within a couple seconds of slowing down to 1000 rpm. While testing I removed the carb cover and the engine ran fine even after being warmed up. Any suggestions as to what to check next will be appreciated greatly.
  #2
Old November 6th, 2002, 06:56 AM
jetdriven jetdriven is offline
Default Re: 1999 175 Mercury SportJet stalls when idling
"While testing I removed the carb cover and the engine ran fine even after being warmed up."Was this testing done with the boat in the water or out of the water hooked up to a water hose?How about starting with running a compression test. Note the condition of each sparkplug as you remove them.
  #3
Old November 9th, 2002, 02:43 PM
When I removed the carb cover it was out of the water, hooked to hose. I had put in new spark plugs not to long ago. Would the fact that the engine ran better with more air be an indication of a plugged jet??
  #4
Old November 9th, 2002, 05:41 PM
I don't think that you can assume a clogged jet by what you have observed. I really recommend that you test for a spark at each cylinder to be sure that all are firing. If you have a timing light, you can just move the inductive pickup connector from one spark plug wire to another and observe the flashing of the timing light. Watch for intermittent firing or lack of plug firing. If all wires are carrying a spark, your ignition is probably OK.Check the compression on all cylinders next. If compression on all cylinders is good and you have good spark to all cylinders, then your problem may be with a carburetor.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Honda 15Hp 1998 Stalls while trolling/Idling MCole Honda & Tohatsu/Nissan Outboards 2 May 30th, 2005 02:39 PM
Merc. Sportjet 175 stalls out after warmup diveguy Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 May 26th, 2004 09:52 PM
Yamaha Engine Stalls While Idling sarnajo Yamaha & Suzuki Outboards 3 July 15th, 2003 05:50 PM
1999 175 sportjet jivaj2 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 August 11th, 2002 07:28 PM
1999 Mercury 115 Stalls jeffvb Mercury & Mariner Outboards 0 July 11th, 2002 08:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
