I am having some continuing problems with my 1989 Rinker Captiva with a Mercruiser 5.0LX Alpha 1. It is a 230 hp model with a Quadrajet carb and electronic ignition. Due to earlier problems, Ive done the following: rebuilt the carb and replaced the float, replaced the fuel filters, plugs, wires, cap and rotor, checked the timing. The boat ran very well initially, but after about ½ hour at a 3500 rpm cruise, it started missing and could no longer maintain a plane. I was able to make it back to the launch ramp at 1200 rpm. I was able to maintain this rpm without problems. After getting back to the ramp an hour later, I tried giving it full throttle, and it seemed to run normally again. According to the gauge, the temp never exceeded 160 deg. Im stumped, and could use some suggestions as to what to look for next. Thanks in advance for the help.
