Reel Estate
- Aug 6, 2001
- 2
I recently purchased a 1979 17' Mako with a '94 100hp Merc. While I am able to fire up the motor easily once I have stopped to fish for a while, I have difficulty restarting the engine; specifically, it tries to start (it engages) but does not "ignite" or fire up...the first few times i took the boat out and encountered this problem I tried pumping up the primer bulb, which led to engine flooding...i was advised that all i needed to start up a "warm" engine was to pull the throttle lever out (into neutral) and throttle up slowly once or twice and turn the key...again, this method worked only after about 20 attempts over a half-hour period... the starter...has anyone else experienced this problem? how do you deal with it?
