  #1
Old June 11th, 2002, 10:38 AM
haggertb haggertb is offline
Default Mercury 40 Four Stroke BigFoot Noise
I have a new Mercury 40 Hp Four Stroke BigFoot on a pontoon boat. The motor is close to brand new, has maybe 5 hours on it. It seems to run ok, but there is this "rubber on steel" noise that changes pitch slightly as the rpm's go up, and gets louder as the rpm's go up. I thought these motors were supposed to be really quiet, but the whine is louder than the exhaust noise. My imagination makes me think it might be the water impeller. How easy would it be to take the lower unit off while the boat is in the water? Or is that a bad idea?? The noise is present at idle, but very faint at idle. The tell-tale stream is very strong at all times.Thanks, Bill
  #2
Old June 11th, 2002, 10:57 AM
Bear Bear is offline
Default Re: Mercury 40 Four Stroke BigFoot Noise
Check the drivebelt tension. Maybe it is to tight./Bear
  #3
Old June 11th, 2002, 05:51 PM
trevorcday trevorcday is offline
These motors are normally very quiet. They do have a funny little whistling sound that they make at about 3000 rpm but it goes away as the rev's climb. If the sound you are hearing is always present this is not what I am trying to describe.
  #4
Old June 11th, 2002, 06:56 PM
wilde1j wilde1j is offline
Bill, sounds like the motor is still in warranty. I'd be reluctant to start taking stuff apart, when the selling dealer should be messing with it, especially if it turns out to be a warranty issue.
__________________
Jim
  #5
Old June 12th, 2002, 04:08 AM
wayne c. wayne c. is offline
Bill, I had what I think is a similar problem w/my '02 90 hp Merc 4-stroke. It was what I call a Harmonic Whine. Does your engine have what Merc calls a FLO-TORQ II Prop ? This prop has a separate plastic hub. If so try a standard prop with rubber hub. When I did this, noise stopped! Got this advice from another on this board. Told dealer about this, he said Merc knew about problem, but wouldn't admit to it. I know it sounds funny, but it took care of problem, let us know what you come up with--Good Luck !
  #6
Old June 14th, 2002, 01:10 PM
Thanks for the information from everybody. The FLO TORQ II answer seems to match my symptom best, as I do have the FLO TORQ II prop. I will have to see if I can get a different prop and try that out.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
2003 mercury 9.9 bigfoot 4-stroke catman48 Mercury & Mariner Outboards 1 March 12th, 2007 01:01 AM
Mercury Bigfoot four stroke 25hp alienator Mercury & Mariner Outboards 0 August 10th, 2006 03:29 PM
mercury 15 hp bigfoot vs 25hp 2 stroke merc jjbuoni Non-Repair Outboard Discussions 4 July 26th, 2005 02:35 PM
Max RPM 9.9 4 stroke Mercury Bigfoot Sailpower jlyar Mercury & Mariner Outboards 0 June 2nd, 2003 01:14 PM
Bigfoot vs. Standard Mercury 4 stroke tjwdrw Mercury & Mariner Outboards 3 January 25th, 2002 03:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
