  #1
Old May 25th, 2002, 06:37 PM
johnno johnno is offline
Default 79 115 HP Blueband Mercury - Dry Spark Plug
Hi All,Although the motor seems to run fine with the earmuffs on, the 3rd spark plug (from the top)is very dry i.e. no fuel on it. The 4th flug (on the same carbie I think) has plenty of fuel on it. So far I have:1. changed the 3rd spark plug2. put a ohm meter on the coil for the 3rd plug to ensure there were no open circuits causing a no spark condition.Any assistance appreciated...
  #2
Old May 26th, 2002, 05:05 AM
JB's Avatar
JB JB is online now
Default Re: 79 115 HP Blueband Mercury - Dry Spark Plug
G'Day, John.Do you have spark on all cylinders? Are all cylinders making power? Running "fine" without a load not a useful indicator. You need to disable each cylinder and see if rpm drops.Let us know what you find.
__________________
RED SKY at night. . .
JB
  #3
Old May 27th, 2002, 12:27 PM
Hi JB,When I pull each spark plug wire off one at a time whilst running the rpm's drop. This doesn't happen on spark plug 3 though.Thanks for advance.
  #4
Old May 27th, 2002, 01:02 PM
JB's Avatar
JB JB is online now
G'Day, John.Sounds as though #3 isn't making power. Did you check it for spark?Is this a 2 carb engine? Are the carbs 2 throat type? You may have a gummed up jet for 1 throat of 1 carb, or, less likely, a bad reed feeding that cylinder.If it has spark, overhaul the correct carb. Inspect the reeds while you have the carb off.If it does not have spark, try switching coils with #4 and see if the problem follows the coil.Let us know what you find.
__________________
JB
  #5
Old May 27th, 2002, 09:13 PM
skier skier is offline
1079 Merc 115 is a Inline 6 with three carbs.Craig
  #6
Old June 1st, 2002, 06:49 PM
Hi JB (& others),Swapped coils between Cyl 2 & Cyl 3 and there is still a dry Spark Plug on Cyl 3. Each carb supplies fuel to 2 cylinders (3 carbs - 6 cylinders) Is it possible that this is a fuel problem even if there is fuel on Spark Plug 4 and it is absolutely dry on Spark Plug 3?I am not sure if this is still a spark or fuel problem?Any help appreciated...
  #7
Old June 8th, 2002, 02:30 AM
Hi All,Any suggestions/advice on this problem is appreciated...
  #8
Old June 9th, 2002, 02:47 AM
Rex Rex is offline
Johnno To me it lookes to be a fuel problem. why #3 plug is not wet. You say it is a inline 6. So the carb. that not work right Is #2 carb. Easy one to get to. Have you tryed to pump the fuel when it running and it stays hard. but i would change coil. I know it does not should right but in there self just don't act the same. get some wd-40 and spray in all 3 carbs. If you spray 32 crab. and the rpm go up then I would say time to rebuild that carb. or get one off of some one you know just to check it out. we are talking about idle some around 700 to 1000 rpm. adjust the idle jet the base line is turn all the way in then out 1 and 1/2 i would say 2 turn. When the engine is running turn the idle jet screw in untell it start rev. up. If i remeber right it has two fuel pumps on it. Just keep in mind. that goes back to when you are pumping the fuel bob to see if it will stay hard.JUST LITTLE ME KNOW IF ANY OF THESE HELPS.REX A. HUBBLE (I hope) Do that on all three. P.s. Mark the screw so you can put them right back to where they were.
  #9
Old June 10th, 2002, 05:43 AM
Rex Rex is offline
Do a compression check first thing.It seem nore like a port is plugged up.That could be the intake or exhust ports.have you thought about the reeds i not sureon this engine.Rex a.
  #10
Old June 11th, 2002, 11:24 AM
Rex Rex is offline
Did you find it?rex
  #11
Old July 3rd, 2002, 09:30 AM
sho305 sho305 is offline
These inline 6's have strange reeds that are on the crank, on a circular plate. They seem to be durable but are hard to inspect. Lot of times a bad reed will make bad idle and go away some at top rpm as air speed goes high in intake and the flow cannot revert back out through bad reed. May show up as puffing out through carb at idle too, not so much if carb is on more than one cylinder. May hear intake noise/popping from that cylinder or is louder intake sounds. Try a $5 spark testor and set for a half inch on bad coil, then I think the second winding in stator starts at 3000rpm if so equipped, and see if spark changes then. Compare to other coils too. Could be CD if coil swap does not change condition. Or, if good it is an airflow/compression problem there. Maybe crank seal, very expensive but not common.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury 400 40HP No Spark to either plug Mercury 400 Mercury & Mariner Outboards 1 July 4th, 2006 11:05 PM
Spark Plug Gap on Mercury csjohnson33 Mercury & Mariner Outboards 10 June 7th, 2004 03:59 AM
What spark plug for my Mercury 1993 150 hp Mercury black max profish Mercury & Mariner Outboards 4 April 23rd, 2003 06:15 PM
Merc 65 blueband no spark english boy Mercury & Mariner Outboards 3 April 21st, 2003 01:42 PM
Mercury 7.5 spark plug Vahevala Mercury & Mariner Outboards 1 March 8th, 2003 01:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
