  #1
Old September 30th, 2002, 05:14 PM
sylvan16 sylvan16 is offline
Default Mariner 50 power loss
My 1984 Mariner 50 has lost power. It seems to start easily and run as smoothly as ever, but it does not rev as high as it used to and won't put my 16' aluminum semi-vee up on plane. It used to do this occasionally when cold, and would suddenly "open up" after about 5 or 10 minutes. Now it does it all the time. This happened rather suddenly. The engine does not run hot, no smoke, the fuel lines and fittings are in good shape and do not appear to be leaking anywhere between the tank and carbs. Fuel filter is not blocked. This model has dual carbs with, I believe, integral fuel pumps. Before I try to take these things off, anyplace else I might look to solve the problem?
  #2
Old September 30th, 2002, 05:51 PM
JB's Avatar
JB JB is offline
Default Re: Mariner 50 power loss
Ahoy, Sylvan.Welcome aboard.I'm not very familiar with your engine, but I can suggest some generic initial troubleshooting tactics.Get a Manual. Without it you may be more hinderance than help to your engine.Check each spark plug wire for a hot blue 1/2" spark to the block.With the engine at idle, disable each spark plug in turn. If rpm drops that cylinder is making power. If there is no drop in rpm that is a dead cylinder.If you have good spark to a dead cylinder, overhaul that carb.Good luck.
__________________
RED SKY at night. . .
JB
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Power loss and Stall w/ '97 Mariner 200 EFI G8r Mercury & Mariner Outboards 4 December 22nd, 2004 03:04 AM
90 Mariner power loss shag rock Mercury & Mariner Outboards 1 November 22nd, 2004 04:37 AM
175 MARINER LOSS OF POWER country boy Mercury & Mariner Outboards 2 May 19th, 2003 11:20 AM
Mariner 70 hp Power Loss Mark Overfelt Mercury & Mariner Outboards 1 May 3rd, 2003 01:23 PM
Mariner 40h power loss paul1 Mercury & Mariner Outboards 4 September 26th, 2002 11:09 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
