  #1
Old September 29th, 2002, 07:55 PM
dslater dslater is offline
Default Mercury Steering linkage problem
My steering linkage on my 1976 175 merc is seized. Its a dual cable rack and the problem seems to be at the motor. The rod at the motor end of one cable appears to be seized in the tube that runs through the motor/transom mount.I've tried persuading it out with a hammer, and a little heat and a hammer but it does not budge.Any ideas?Thanks
  #2
Old September 30th, 2002, 05:54 PM
Reel Appeal Reel Appeal is offline
Default Re: Mercury Steering linkage problem
Super Dave, Disconnect the steering linkage arm from motor.If the motor moves by hand then it's a frozen cable in the tilt tube(like u said).If the motor does not move after disconnecting all steering from motor.Then,the steering shaft(vertical)that runs through the motor bracket is seized.Try penetrating oil,heat,grease any fittings.There is a product called PB Blaster that works great.If any fitting does not accept grease,use heat on the area,then grease while still warm(hot).
  #3
Old September 30th, 2002, 08:16 PM
Thanks Reel Appeal. I took the linkage off and it appears to be seized in the "tilt tube". I'm going to remove the tilt tube with the rod still within so I don't have to work with a lot of heat near the motor. I'll try the "grease while hot" idea as well.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Shifter linkage problem Mercury 7.5 Steve Chapman Mercury & Mariner Outboards 4 March 29th, 2006 03:40 AM
Mercury XR-4 Power Steering Problem Jtskor Mercury & Mariner Outboards 0 June 13th, 2005 09:20 AM
1996 200 HP Mercury Lower Unit or linkage Adj. Problem jorwalke Mercury & Mariner Outboards 1 January 20th, 2005 07:16 AM
Mercury Steering Problem ajrspotter Mercury & Mariner Outboards 0 July 29th, 2002 07:25 AM
steering linkage deli man Mercury & Mariner Outboards 1 June 28th, 2002 12:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
