Re: Mariner 40h power loss
Sounds like fuel restriction or fuel pump needs replacing. I would check all the fuel lines for air leaks, replace primer bulb and connectors at Fuel Tank and the Motor. If this does not do it, replace the Fuel Pump. Can you give us a Model and Serial Number? Would help in diagnosis!
__________________
Rick
"Boating is Life...All the rest is just Details"
