Hi Jamescody,
The ports you are describing double as exhaust and water exit.If your motor has a tell tale stream,you will see a little water coming out of these at idle(maybe) off idle,expect to see more(higher rpm's).Sounds normal so far....
Water at any speed coming out is normal.
Your last question would be best left to the Mercury(and other)designers.
