  #1
Old September 14th, 2002, 04:28 PM
hbaldwin hbaldwin is offline
Default Choke Problem, 1983 Mercury 25hp
Being a novice with boats I need some advice. I have a 1983 Mercury 25hp. There is a control on the front of the motor that appears to adjust the choke (manual setting?) and there is an automatic choke when I push in the key to start the engine. I do not have a manual fo rthe motor but should have one sometime this week. My question/problem ... I started the engine by pushing in on the key and turning it, the engine started just fine, it seems to want to die but just barley stays running. I wait for a seconds and shift into forward. The motor dies and will not restart. After several attempts to start the engine nothing worked. I then moved the manual choke control and the engine started, runs very well. OK now the question, how am I suppose to actually start the engine and what should the manual choke be set to?Thanks,Hayden
  #2
Old September 14th, 2002, 04:49 PM
tallcar's Avatar
tallcar tallcar is offline
Default Re: Choke Problem, 1983 Mercury 25hp
I have a '56 MercElectric, that has the same problem...it has a manual choke as well as a electric choke... the manual states to not choke a warm engine, so if the auto choke works,... then it is in fact choking a warm engine...this problem has been solved by removing the electric choke...and I have to manually choke the engine on cold starting...but not aftrer it is warmed up....sorry about no concrete advice, but just info for you...good luck...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1983 Mercury 25hp question bassassin Mercury & Mariner Outboards 5 October 17th, 2008 12:22 AM
1983 115hp Mercury bogging down or choke problem? TimDollar Mercury & Mariner Outboards 20 January 30th, 2007 04:06 PM
1983 25hp mercury Help! FireNHunt Mercury & Mariner Outboards 6 September 27th, 2006 09:15 AM
1993 25hp Mercury choke rlindsay Mercury & Mariner Outboards 6 March 19th, 2005 06:05 PM
Will 1983 mercury 25hp lower unit fit 1987 model? clintb Mercury & Mariner Outboards 5 February 4th, 2004 03:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
