1975 Mercury 850 rebuild powerhead or not?
Serial 4235590. I think it's a 1975. I have it apart and found what I thought I'd find. The water pump impeller is shot. Top cylinder of inline 4 is not scored, I think. Rings are pretty worn on that cylinder and piston looks a bit ugly. The other 3 cyl. look good and compression was good.... My question is, since I have it apart, does it make sense to replace other moving parts...bearings, wrist pins..., even if they're working fine. Or do I leave well enough alone. I'm not an experienced rebuilder, I just want to replace anything that should be replaced since I have it all apart.
