  #1
Old September 3rd, 2002, 12:35 PM
mcslee mcslee is offline
Default 1979 Mariner 8hp lower unit won't come off.
Good afternoon. My 1979 8hp Mariner lower unit won't come off. I've be trying to get to the impeller because the engine has been overheating and I beleave the impeller to be the problem. Please help. Thanks.
  #2
Old September 3rd, 2002, 01:12 PM
snapperbait's Avatar
snapperbait snapperbait is offline
Default Re: 1979 Mariner 8hp lower unit won't come off.
Do you have ALL the bolts & nuts off?? Sometimes they hide one or two on you... Is corrosion the problem... A good dose of PB blaster or WD40 should help.. let is soak.. Last resort try heat.....Check for a bolt on the underside of the cavitation plate right above the prop... DO YOU HAVE A MANUAL?
__________________
Now understand, Commander...
That torpedo did not self destruct...
You heard it hit the hull...
And I...Was never here...
  #3
Old September 3rd, 2002, 02:40 PM
There are (4) bolts that seem to hold the lower unit on. When I remove them, it drops apx. 1/4". I have removed the screw above the prop, and didn't do anything.
  #4
Old September 3rd, 2002, 03:19 PM
Have you tried a LITTLE force? sometimes the water tubes and or the drive shafts stick from corrosion..A wood block and a rubber mallet might help or pry as a last resort.. DO U HAVE A MANUAL. There's other stuff you need to know about like position of the shift shaft for reasembly ECT....
__________________
  #5
Old September 3rd, 2002, 03:23 PM
I have wacked it pretty hard a few times with a rubber mallet, and it didn't seem to move. I ordered a repair manual last week and it hasn't arived yet. Someone said something about putting it in gear to remove the unit? Still didn't work.
  #6
Old September 3rd, 2002, 03:50 PM
I'd have to say the drive shaft splines on the crankshaft are rusty, the shift shaft too possibly..It's gonna take some force.. You might try turning the beast upside down and give everything inside the drive shaft housing a healthy dose of penetrating oil.. just make absolutely sure theres no water in the engine..Then wait for the manual in case we missed something....
__________________
  #7
Old September 3rd, 2002, 04:10 PM
mcslee Check out this website It shows exploded views of everything.. if you have your serial # you can find the view of gearcase.. www.mercruiserparts.com/SelectProductLine.asp
__________________
  #8
Old September 4th, 2002, 04:56 AM
Thanks for the info. I'll give it a shot. Chris
  #9
Old September 8th, 2002, 06:08 PM
I received my manual on Sat. and set out to concour this beast. I did everything as per the manual and still the lower unit would not come off. So I decided to get a HAMMER and a 2x4. Whack, whack, CRACK. I broke one of the lower side fins off. I'm not sure what to do now?? Thanks.
  #10
Old September 8th, 2002, 06:14 PM
ob ob is offline
Cavitation plate can be re welded and shaped after you are successful in removing lower unit,as long as it didn't fracture prop shaft housing.Not familiar withyour motor but if there is a shift shaft pin bolt not removed maybe that is your problem.had a friend with 6 hp merc and it had a shift rod pin bolt .7/16 hex.
  #11
Old September 8th, 2002, 06:39 PM
Sorry to hear of your OUCH...I'm stumped too... It's been a while but I don't recall any bolts or pins holding the shift shaft..
__________________
  #12
Old September 8th, 2002, 06:55 PM
go to this site and click on gear shift linkage... Check the exploded view..I think you'll find your problem...www.mercruiserparts.com/select_docs3a.asp?doc_nbr=+83774+++
__________________
  #13
Old September 8th, 2002, 07:10 PM
ob ob is offline
Looks like there is one
  #14
Old September 8th, 2002, 07:18 PM
I stand correceted....
__________________
  #15
Old September 9th, 2002, 03:28 PM
I'm not sure what your looking at how how to get to it. Please explain. Based on the Pic. Thanks
  #16
Old September 9th, 2002, 03:33 PM
I'm not sure what your looking at or how to get to it. Please explain. Based on the Pic. Thanks Sorry about the spelling.
  #17
Old September 9th, 2002, 07:36 PM
This view is your entire shift assembly from the gear shift selector to the lower unit...Locate the cotter pin (part #13 on the view)near the shift selector by the power head and remove it.. This should allow the lower unit to drop far enough to access the bolt and shift rod connector(parts #15-18)... You should be able to see the bolt and connector between the lower unit and the drive shaft housing.. Remove the bolt and seperate the connector... Thats it..
__________________
  #18
Old September 11th, 2002, 02:24 PM
I unfastened the linkage and the lower unit will still not come off. I can feel the clunk when it moves a 1/2" and stops, but can't figure out whats holding it back?????
  #19
Old September 11th, 2002, 02:43 PM
ob ob is offline
can you get clear view of shift rod and know that there is no attachment clevis on it that wont clear grommet tube?because if it is disconnected the only other possibility is the driveshaft somehow is binding.
  #20
Old September 11th, 2002, 04:14 PM
Yes I can clearly see the shift shaft. After I unbolted the clamp, you could see that nothing was at the end of the shaft..
  #21
Old September 11th, 2002, 04:33 PM
ob ob is offline
Weird deal ,the only thing i can imagine would be the driveshaft somehow.If you haven't already try working unit up and down to see if 1/2 " changes at all as driveshaft binding on spline.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 inline 6 lower unit water GOTFIVE Mercury & Mariner Outboards 5 April 10th, 2005 12:53 PM
1979 40 HP Merc Lower Unit Cow99boys Mercury & Mariner Outboards 2 October 31st, 2004 03:35 PM
lower unit Evinrude 4 HP 1979 hsk Johnson & Evinrude Outboards 2 October 27th, 2003 09:41 AM
1979 johnson 100 lower unit compatibility wheineman Johnson & Evinrude Outboards 0 July 26th, 2002 05:39 PM
1979 Chrysler 70HP Lower Unit dymo Force & Chrysler Outboards 2 May 8th, 2002 12:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
