  #1
Old August 31st, 2002, 12:57 PM
spekltrout2002 spekltrout2002 is offline
Default 25 hp Mariner hard to start
have a 1983 25 hp Mariner, (Japanese made) I just had the carburatorre-built as it would not idle at low speed and is extremely hard to start.Even after having the carb rebuilt it is still hard to start and at highspeed and now at low speed it wants to cut out on me. at the low speed itseems that it is not getting the proper amounty of fire. Could it be thecoil? I bought this boat and motor used so I do not know a lot about it.
  #2
Old August 31st, 2002, 08:27 PM
Reel Appeal Reel Appeal is offline
Default Re: 25 hp Mariner hard to start
spekltrout, Remove the sparkplugs and tell us what they look like....Also,check the fuel filter for blockage,etc.
  #3
Old September 1st, 2002, 10:20 AM
I checked the plugs,they are new but it appears that there may be some (slight) moisture on the bottom plug, i also checked the fuel filter, it is clean, in looking at the engine block behind the fuel filter area it appears to be some mositure there too, but i am not sure that it is water.
  #4
Old September 1st, 2002, 03:56 PM
John H1 John H1 is offline
1. FUEL--Try a new fuel line, and when you’re running it at ¼ - ½ throttle and it tries to cut out try squirting some premix into the carb, NOT A WHOLE LOT, see if it picks up. Use an oil type can pump type. 2> SPARK---- Pull plugs wire-INSULATE YOURSELF WELL ( one at a time) short between plug connector in wire and spark plugs head (screwdriver) about 3/8” gap, as running watch spark jump, should be constant and forceful at idle…. Two things in order to have combustion….John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mid-1990's mariner 3 cylinder 60 hp hard cold start kentrx1 Mercury & Mariner Outboards 4 July 17th, 2005 05:58 PM
40hp Mariner, hard start, rough idle,planes off then dies Jeff Leek Mercury & Mariner Outboards 2 January 31st, 2005 04:10 PM
Mariner 50hp (84) Hard start (excess fuel?) ZenBasser Mercury & Mariner Outboards 0 September 12th, 2004 12:00 PM
Mariner 150 - hard to cold start and stalls on low revs Gnirts Mercury & Mariner Outboards 9 August 13th, 2004 05:23 PM
82 Mariner V-6 150 HP, Hard Start, Rough Idle, Won't Run ccnoah Mercury & Mariner Outboards 1 June 17th, 2002 12:41 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
