Hello all,<br />I am replacing a 1988 force 15 with a 1976 johnson 25 on my 14' semi v aluminum boat. <br />Mt transom is 15 3/4", which worked out fine for the force as the cavitation plate was even with the bottom of the boat. Not so with the johnson. Even though it's a regular shaft (18" from the where the mounting braket hits the transom to the cavitation plate) the cavitation plate will be about 2 1/4" below the bottom of the boat. I have read conflicting reports about whether this will be a problem or not an would appreciate any advice. My prop info is this: "Michigan" is stamped on the prop, along with the numbers 510 and 16 (or is that 19 upside down?. not sure what all of that means. It is a three blade aluminum.<br />Thanks for your time and consideration.<br />Chris
