  #1
Old August 19th, 2002, 08:59 PM
Sea Hawk Sea Hawk is offline
Default 1995 3.0 liter 225 mercury carb. leak
after running all day, I raise my motor for the night. The next day I notice there is oil running down the control cables. not a large amount, but enough to be noticed on a white deck. I removed the cowling and saw a bit of two stroke oil laying in the bottom under the carbs. It appears that it is clean unburned oil that is running out of the carbs when it is tilted up. What could cause this and is it a major problem. I have looked all over the motor and have found no other leaks or wet, oil soaked areas. Any ideas?
  #2
Old August 20th, 2002, 07:48 PM
Reel Appeal Reel Appeal is offline
Default Re: 1995 3.0 liter 225 mercury carb. leak
Hi Sea Hawk, I have a '96 Johnson 225 that does the same thing.I think alot of outboard owners encounter this situation.The gas/oil mixture in the carbs is spilling out(albeit a small amount) into the airbox(on front of carbs)whenever the motor is tilted up.The gas in the airbox eventually evaporates leaving oil to leak through the motor cowling onto your nice clean boat.Also had a '86 Merc.175 w/same.Usually this is not a problem unless it is excessive(which might indicate a carb/float problem).The only way to avoid this is to shut off fuel supply to motor and run engine till out of gas/stalls,then Tilt.You might want to remove the cowling and check the drain/screws on the carbs to make sure they are tight.Also,are the carb bowl gaskets good?One(or more)of the carb floats could be stuck open(allowing carb to dump fuel)although this is unlikely if your motor runs OK.If you are using more fuel than normal check under the hood for leaks.If not,does not sound like a real problem.
  #3
Old August 20th, 2002, 08:38 PM
Greg Lawrence Greg Lawrence is offline
on my 60 hp johnson it does the same thing.. it seems to come from the nipple on the front of the intake manifold, so i reassembled the airbox, seald it to the carbs with permatex, and hooked the drain from the airbox to that nipple on the manifold. i havent seen one drop o gas-oil.
  #4
Old August 22nd, 2002, 11:06 PM
Thanks Reel and Greg. I certainly appriciate your help. I will do a little more investigating and make sure that there are no other possible problems. Then I will chalk this one up to being the nature of the beast. I was concerned at first, but now I feel much better. Hope I can return the favor some day. Thanks again and happy boating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
90 horse mercury sportjet 1995 exhaust leak shroom Mercury & Mariner Outboards 5 July 11th, 2006 06:28 PM
Carb. Leak on Mercury 25 hp Blacky Non-Repair Outboard Discussions 1 April 30th, 2006 06:34 PM
Carb. Leak on Mercury 25 hp Blacky Mercury & Mariner Outboards 1 April 30th, 2006 06:34 PM
1995 MERC 3 LITER CARB oct Mercury & Mariner Outboards 4 May 26th, 2003 06:48 PM
225 mercury 3.0 liter v-6 carb 1995 hst Mercury & Mariner Outboards 2 June 24th, 2002 08:10 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
