  #1
Old August 13th, 2002, 09:00 PM
jamescody jamescody is offline
Default 82 mariner 90 hp running weird
Little background...took the boat out the other day, max rpms was only about 3800...took 'er home and went thru it, found a coil that had burnt back the copper where the wire plugs into...replaced that, took it back out onto the water, 5000 rpm no problem, ended that day by decarbing the motor...previous owner said he had never done that...Well, took her out today, she was running like a champ, by the end of the day, the hole shot was suffering and I lost 500 rpms. you can always tell when its going to act up because it is hard to start after shutting it down to load a skier......and when you nail the throttle, you get about half way and it just dies, if you pull back on the throttle and kinda ease into it...it goes. One thing I did do was change from Shell Nautilus oil to Quicksilver plus.Any ideas, hints or suggestions?
  #2
Old August 14th, 2002, 04:55 AM
rwise rwise is offline
Default Re: 82 mariner 90 hp running weird
some on this board have said that after a decarb "change the plugs" as for thr oil a lot of us use super tech tcw3 from wall mart. use the search and put in tcw3 for more info on oil.Richard
  #3
Old August 14th, 2002, 06:07 AM
moose211 moose211 is offline
i would to a comp. test sound like you my have a bad head gasket
  #4
Old August 14th, 2002, 08:59 AM
did a compression test after I changed the coil, the old girl had 120 psi straight across...yup, I changed the plugs after the decarb.......second trip out I pulled the plugs and there was a fair amount of carbon balled up on a few....but I hear thats normal after a decarb, may have to clean plugs a few times until all the carbon is thrown..I went to wallmart here in Calgary, But I couldnt find that oil, but how can you go wrong with Quicksilver?
  #5
Old August 14th, 2002, 10:12 AM
what200 what200 is offline
There is nothing wrong with mercury oil. I would have to guess there is a fuel delivery problem, because you say the problem exists on startup and higher rpms. However, you can't rule out ignition at this point. I would try to rule out fuel delivery problems (you can definately rule out head gasket since there isn't one.) When the motor bogs get someone to pump the fuel bulb to see if that changes anything. Or after it bogs and dies, pull the plugs to see if all are wet with gas.When the motor is acting up, is the idle quality affected?
  #6
Old August 14th, 2002, 10:52 AM
What200..The engine idles great since I changed the coil, before it used to stall when put in gear...Its definitely a wierd one 'cause its intermittant, sometimes you can put the throttle full open and the thing jumps and planes right away, next time, she'll sputter, and unless you back out of it, it will die....I'm an auto mechanic by trade, and I'm **** sure the thing is leaning out....I'm tending to think that maybe the fuel pump diaghram should be changed out....probably a good place to start.Another thing is, why is it hard to start when its hot?? These **** outboards are going to be the death of me!!lolJames
  #7
Old August 14th, 2002, 11:56 AM
If you pump the bulb while it is bogging that helps I think that would point to either the diapham or a vacuum leak.Inlines are supposed to be hard to start cold not hot. I think that would point towards your fuel pump losing prime somewhere.The only thing about it, is that if the problem turns on and off like a switch that would be more like a stator or switchbox problem, but could be diagnosed with a timing light on each plug wire.
  #8
Old August 14th, 2002, 03:10 PM
What200......If it was a stator or switchbox, I think it would lose more than 500 rpm.....when the coil was shot, the best it would do was about 3800 rpm...I think its a fuel problem.Thnx for the suggestionsJames
  #9
Old August 14th, 2002, 09:28 PM
sjksjk sjksjk is offline
I have a 79 140hp Mariner L6 that has had very similar symptoms. I had a new fuel line/bulb I installed and did not change out the receiver in the motor that the fuel line connects to. There was enough difference to restrict the flow and caused similar problems as you had. Just a thought, good luck.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Gamefisher 3.5hp spark plug and weird running flyingduck Other Outboard Brands 7 November 1st, 2005 11:19 AM
Mariner 150 still running HOT. rocks Mercury & Mariner Outboards 8 July 10th, 2005 05:54 AM
'95 Mariner 60--running on 2/3 Dman Mercury & Mariner Outboards 2 April 16th, 2004 05:34 AM
mariner 5hp not running right in gear boomerboy Mercury & Mariner Outboards 2 June 6th, 2003 09:18 PM
20 hp Mariner running bad gprestridge Mercury & Mariner Outboards 5 May 21st, 2002 03:42 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
