  #1
Old August 7th, 2002, 03:30 PM
bpet298 bpet298 is offline
Default 90hp Mariner putting out 17 volts to battery
I tested it at the battery just to make sure my voltmeter was not off. Is this normal? Can I do anything about it? I don't think it was dong this a weeek ago.
  #2
Old August 7th, 2002, 05:08 PM
Trent Trent is offline
Default Re: 90hp Mariner putting out 17 volts to battery
Un-regulated systems will do this with a fully charged battery. Turn a few things on like Nav. lights and what ever you have and see if the voltage comes down. Make sure you keep the battery topped off with distilled water.
  #3
Old August 7th, 2002, 09:33 PM
tuber tuber is offline
Could clean connections, check wires, voltage is directly related to resistance. Checking the accessories as Captain Trent advised is a great idea, if the voltage jumps as a given circuit is energized thats the circuit to begin cleaning.
  #4
Old August 8th, 2002, 07:20 AM
Thanks for the reply guys, I think my wires are ok. I did replace the stator a month ago and can't help but think that may have something to so with this. The battery is full of water andI have even unhooked the wire to the tach. (which has not worked since I got the boat).Please read my post of 8-6 for the full story. Anything else I can try?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motors putting out 18 volts & not working right, HELP !! Scali Mercury & Mariner Outboards 12 June 2nd, 2005 02:54 PM
85 Mariner-fast idle causes gears to grind putting in gear Jeff Leek Mercury & Mariner Outboards 4 April 24th, 2005 09:19 AM
How many volts to battery at idle?? Mikemaster Johnson & Evinrude Outboards 12 August 10th, 2004 06:06 PM
21 volts out of battery revertmastec Non-Repair Outboard Discussions 7 June 22nd, 2002 07:35 PM
17 volts to battery. sjksjk Mercury & Mariner Outboards 2 April 21st, 2002 06:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
