Hi all,
I think I got a few clues the other day about my lack of power problem. When the boat bogs dwn, I touch the choke button and it picks right up for a second. If I keep on tapping the button, the engine accelerates and then finally dies.
Since this seems to indicate fuel starvation, I primed the carbs with the bulb, and then ran a hose from the pump into a bottle and started the engine.
It ran for 20 seconds or so at 1000 rpm until it ran out of fuel, and the amount that pumped into the bottle wasn't enouch to fill all 3 float bowls
(maybe about 3 oz.).
I am assuming that the fuel pump delivery is the culprit, but I don't know what to do about it.
I took the pump apart and found the gaskets, diaphram, and check valves OK, (someone had recently replaced them by the looks of things)
and there is plenty of fuel getting to the pump.
A light squeeze on the bulb pumps a ton of fuel to the pump inlet.
I guess my question is; Is it possible that the primary compression is too low (weak signal to the pump)? I don't know how to verify this, but the engie runs great (50+ mph) when it's getting enough fuel, so I don't really want to tear it down just to improve fuel pump performance.
Are the pumps on these engines just marginal in design (common problem?)
Is there any updated pumps or bulletins that would improve my pump performance?
Finally, if I can't get the pump working well, has anyone out there ever retrofitted another type of pump, possibly electric?
I appreciate any help that you can give.
Thanks, John
