  #1
Old July 31st, 2002, 12:01 PM
catbear catbear is offline
Default Mercury 175 XR2 powerhead won't idle
It will start as usual, run at speed, and idle with a slightly advanced throttle all day (hours and hours i've run it). But when I put the throttle back to 0, it stalls out. 100 hours on the motor, model year 2000, bought new. It sat for about six months being started occasionally, but would not idle then either.Emptied the gas tank and put in fresh gas. No change.Replaced the plugs. No change.I ran a 4x solution of carb treatment through the engine (two jugs in six gallons of gas) at slightly advanced throttle. Emptied the tank and put fresh gas in. No change.Sprayed lots of carb cleaner at it, running and not running. No change. I've sprayed carb cleaner down all the air inlets and bleed ports. No change.It's got 3x2 barrel carbs, and they look very clean inside.I have not adjusted any screws, needles, or linkages on the carbs or motor to attempt to rig it, or otherwise fool around with it (although i know that tweaking the throttle linkage forward would make it idle, i know that's not the right solution). The **** service manual is back ordered, so I'm in the dark about what does what.Thoughts? Suggestions? PDF files of relevant pages in the service manual? I really don't want to take it to a dealer, i want to fix it and understand what's wrong with it so i can take care of it myself.Thanks.
  #2
Old August 1st, 2002, 02:43 AM
orca orca is offline
Default Re: Mercury 175 XR2 powerhead won't idle
G'Day. I think these motors have an idle speed module. the module has to be disconnected to set the timing, it may not be connected. I will check and get back in 24HRS. look for a white wire with a black stripe. it may not have been connected.
  #3
Old August 2nd, 2002, 03:18 AM
G'Day. Sorry, havent yet got the info regarding idle module,does the problem occur on the water or on the muffs, These motors have a tuned exhust and run like dogs on the flusher but run much smoother in the water.
  #4
Old August 2nd, 2002, 05:58 AM
hii don't think there's an idle speed module; there's a cold start solenoid and that's about the only thing electronic connected to the induction system, and all it does is shove a bit more gas in for a few seconds.anyway, the problem occurs both in and out of the water.thanks for your thoughts
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury powerhead??? dcfrank Mercury & Mariner Outboards 4 March 11th, 2006 05:16 PM
'96 Johnson 115 crossflow sputters at idle after powerhead rebuild?? crappie_condo Johnson & Evinrude Outboards 25 May 25th, 2005 07:30 PM
Mercury 115 hp powerhead question sdgs Mercury & Mariner Outboards 0 June 15th, 2004 04:23 PM
Mercury Powerhead replacement mgroely Mercury & Mariner Outboards 1 June 17th, 2002 11:02 AM
Mercury 25hp powerhead? TonyW Mercury & Mariner Outboards 1 February 17th, 2002 05:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
