  #1
Old July 29th, 2002, 02:29 PM
scootys scootys is offline
Default 40 HP Mariner magnum start probs
Hi, I just purchased a used pontoon w/ a 1994 40 mariner 4 cyl. The boat can be very tough to start either cold or warm. Any suggestions out there? Choke or no Choke? Throttle or no? Thanks
  #2
Old July 29th, 2002, 03:14 PM
steelespike steelespike is offline
Default Re: 40 HP Mariner magnum start probs
Scoot, Be sure there is good spark.New plugs. Be sure the choke is closing and opening right. Be sure you follow the proper starting procedure.When cold Squeeze the primer bulb till hard set the throttle to the correct starting position.If there is a fast idle setting use it push the choke and turn the key. When warm set the throttle and it should start right up.If the motor has set around a lot you may need to tune up the fuel system.
  #3
Old October 14th, 2008, 08:56 AM
elsadognina elsadognina is offline
Red face Re: 40 HP Mariner magnum start probs
i had the same problem till i started using the 8 count procedure.ie prime bulb turn key to on but not to engage starter push in on choke on ignition button for 8 count, pull up fast idle fully, then turn key fully, this works great for me on same engine as yours, hope it works for you too.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner Magnum 40 Norwegian Viking Mercury & Mariner Outboards 43 September 22nd, 2005 07:35 AM
Mariner Magnum 40 won't start hotwhl44 Mercury & Mariner Outboards 1 June 21st, 2004 06:07 PM
Mariner 40 Magnum from 97 wont start spiken Mercury & Mariner Outboards 0 August 2nd, 2003 10:22 AM
Mariner 40 Magnum old salty Mercury & Mariner Outboards 2 September 29th, 2002 08:13 PM
mariner Magnum old salty Mercury & Mariner Outboards 1 September 29th, 2002 09:32 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
