  #1
Old July 25th, 2002, 04:35 PM
mikeyc mikeyc is offline
Default 1982 mercury 150 v-6 head bolt torque settings/sequence
Will someone please help me on what the torque setting and sequence should be on a 1982 v-6 mercury 150 black max outboard with new head gasket.Any help would really be appreciated.
  #2
Old July 25th, 2002, 06:18 PM
Steven R Langston Steven R Langston is offline
Default Re: 1982 mercury 150 v-6 head bolt torque settings/sequence
I suggest you purchase a manual....when you're as mechanically as I am - they're cheap compared to the 'rework'.... Hope this helps: (From the Seloc Repair Manual)"Install and tighten the head bolts to Specifications in the Appendix (the specs for the 150 V6 head bolts are 35 ft lbs - check torque value again after powerhead has been operated for approx. three hours.) Tighten the bolts in three stages following the pattern given(here's where I prove I'm not an artist...forgive me)TOP10....9.......6.....5.......2.....1.......4.....3.......8.....7.......12...11BOTTOMThere's different torque specs for the '74 degree' block - so you need to make sure of yours..(the 74 degree block is 12.5 ft lbs)Good Luck........
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
mercruiser 4cyl head torque sequence johnguz76 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 May 5th, 2006 02:05 PM
Head bolt torque settings? glennkil Johnson & Evinrude Outboards 20 February 10th, 2006 02:11 PM
Suzuki DT65 head bolt torque settings Jon Sharp Yamaha & Suzuki Outboards 1 August 30th, 2002 05:31 AM
Suzuki DT65 head bolt torque settings Jon Sharp Yamaha & Suzuki Outboards 0 August 11th, 2002 04:38 AM
Head Gasket Torque Sequence on a Force 85 hp (1985) Jaymz007 Force & Chrysler Outboards 0 June 25th, 2002 06:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
