G'Day. Forgive me if I am wrong but I don't think that Mariner made a 55HP in the late 80's. If the motors are 2 Cyl then they are Built by Yamaha in Early 80's If they are 3 Cyl then they are Mercury built.
As to fuel mixture. I am not aware of any 2 stroke putboard that cannot run on 50:1, even if the manufacturer recommends 100:1. With modern TCW3 oil and the correct plugs you should not get oiling problems unless there is a problem with the motor. Cylinder head(2 Cyl gasket only) or maybe ignition. You may get an oiling problem if you are idling for a very long tome. 40 mins or more.
Hope this helps. Good luck.
