mercury 4hp stuck in forward HELP
I replaced the water pump impeller on my mercury 4 hp,("mercury 40" on motor, about 1975), but when I put the lower unit back in, it seems to be locked in gear and won't go into neutral. It is like the shift rod won't push whatever it should to disengage the pinion gears. I know there has to be a trick to get the shift lever rod and lower unit back together right, but could someone help out. THANKS
