If the motor is running on all cylinders, you may be able to play with the set up and raise the X dimension. If the motor is running correctly, this is a classic example of the motor being too low.
As suggested, verify the running condition and get back to us. I'm guessing you have a jack plate so raising the motor will be easy.
Good luck!
