Re: 9.8 Mercury Stuck in Forward Gear
First off ,change the gear oil.If you open that gearcase and it comes out water ,or worse, rusty water ,that may give you a clue.Next ,drop the gearcase.Two nuts ,one in front at the top of the gearcase by the lower motor mount and one under the plate by the water pickup.Once the case is off and you still are frozen up then you know it is at the shifter and you will have to clean all that up.
