  #1
Old July 12th, 2002, 01:52 PM
David R David R is offline
Default Limiting RPMs on Mercury
I've a 1988 70HP Mercury that requires a little extra rpms when starting from cold. Now I know to keep the rpms below 2500. The rest of my family and particularly my niece, aren't very mechanically savyy. The controls for this motor have the separate cold idle lever or warm-up lever. The movement of the lever allows revs of probably more than 5000.The manual doesn't discribe a setup for this part of the controls. Is there away to limit the neutral rpms?
  #2
Old July 12th, 2002, 04:54 PM
skier skier is offline
Default Re: Limiting RPMs on Mercury
Sorry, I had one of those controls and had the same problem and I have not found a way to limit the RPM's. Mine wouldn't go above 3500. All that lever really does is advance the timing, and the fact that your timing is not controled by a distributer, I doubt that there is any way to limit it.Sorry.Craig
  #3
Old July 13th, 2002, 12:05 AM
hondon hondon is offline
No way that I know of to limit the travel of that warm up lever.Problem is that sometimes you need that extra travel in a flooded or extreme cold start situation.Try talking very patiently with yor neice and express to her how much you love, her and the time you spend on the water with her,then share with her the way you would like YOUR engine to be started and why it should be started that way.Remember that each freewheel situation could be denying you time later on down the road.
  #4
Old July 16th, 2002, 08:33 AM
Thanks for the replies guys. I also talked with the marina mechanic yesterday, and he said the same thing. I might open the control box and see if a mechanical stop can be added. There is a lot of movement in the lever before anything happens, which makes it that much harder to use. It would be nice to say "don't lift the lever more than thickness of your thumb" or something like that. As it is, its like 2 1/2 inches.BestDavid
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Rev Limiting Screw? DUKE1 Johnson & Evinrude Outboards 1 August 13th, 2006 09:38 AM
Replacing Trim Limiting Switch ta400man Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 June 4th, 2006 09:46 PM
What is the reason for limiting trim adjustment ? Jimmie.jazz Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 9 February 8th, 2005 06:09 PM
Bypassing trim tilt limiting switch Johnboy85323 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 14 July 15th, 2004 02:31 AM
93' 175 mercury will not go over 2000 rpms? ranman Mercury & Mariner Outboards 1 July 2nd, 2003 03:38 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
