  #1
Old July 9th, 2002, 06:33 PM
RAB1397 RAB1397 is offline
Default '87 Mariner 60hp stalls into and out of gear.
1987 60hp Mariner starts good and runs WOT but I have an intermittent problem going in and out of gear. The neutral idle is smooth and I can rev the motor in neutral without any stumble. When I slide it slowly into gear it will quit. Or sometimes after running wide open without any problem when I shift back to Neutral it will die. However most times it will run good at idle speeds if I am able to get it into gear without stalling, also after backing down from high speeds.I've cleaned the fuel filter, change plugs, run from an external 2 gal tank with new premixed fuel(I have a mixer on board) and replace the primer ball. I have had the carbs off and cleaned them but I am not an expert so I don't know if I cleaned them well or if it needs a rebuild or rejetting. Seems like its a carb problem but I am a rookie at adjustments or rebuilds.Thanks guys.
  #2
Old July 10th, 2002, 09:45 AM
Default Re: '87 Mariner 60hp stalls into and out of gear.
I've also noticed that if I do get it into gear without stalling, if it runs rough I can tap on the choke and it smooths it out.How complicated is doing a carb rebuild? What's the cost? What kind of problems should I watch out for?Thanks
  #3
Old July 11th, 2002, 10:14 AM
^ any input is greatly appreciated. Is it possible for idle adjustments to get out of wack or move over time. I want to readjust the idle but I see two screw on the front of each of the two carbs. One must be the idle adjust what is the other screw? My manual says adjust 1-1/4 turn, then back it out to RICH, then bring in back in to LEAN and split the difference. How do you go about this with two carbs. Do you work on one first, then the other, or do you slowly work both of them at the same time, for example 1/8 turn each, back and forth between both carbs.Thanks for any input.Rookie
  #4
Old July 12th, 2002, 12:34 PM
one more time,does anyone have any suggestions for a rookie, or do you have to be Mr. Goodwrench to get some help????
  #5
Old July 12th, 2002, 05:20 PM
lawndog lawndog is offline
Roger Dodger,Be careful, I got chewed out for gettin' impatient just the other day. Somebody will have mercy on you soon.Roll Tide
  #6
Old July 12th, 2002, 06:16 PM
suzukidave suzukidave is offline
If no one else will help, I'll try but I'm not a mechanic, just a boater with a couple fo wrenches . First never put your motor slowly in gear, put it in decisively or you'll damage the lower unit gears. If that stalls it then fix the stall, don't sacrifice your lower end.Second, get a better manual. It should tell you exactly how to adjust the idle, and also help you troubleshoot your symptoms. If you have an actual shop manual, grab a clymer too -- they are written for the non-wrench and fill in many gaps.Third, you haven't eliminated the rest of the fuel system. Does the primer bulb stay hard when running and does pumping it cure the problem? Check the fuel pump and the choke adjustment. Then check the fuel lines for loose connections, missing o-rings or leaks. If none of that works it may be carb rebuilding time but I am not the guy to tell you to go there. Hopefully someone will pick this thread up.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
60hp 1987 evinrude stalls at low rpm & when shifting in gear fab Johnson & Evinrude Outboards 7 May 23rd, 2008 01:12 PM
1992 60hp 3 cylinder stalls going into gear koolerb Johnson & Evinrude Outboards 1 June 29th, 2006 09:09 PM
Mariner 40 stalls going into gear!!!! Jamrude Mercury & Mariner Outboards 2 March 28th, 2006 10:30 PM
1983 60HP Evinrude stalls when put in gear when warm athertop Johnson & Evinrude Outboards 2 September 4th, 2004 01:11 PM
johnson 60hp stalls when put in gear and low idle for a while mookieo2 Johnson & Evinrude Outboards 2 June 13th, 2002 07:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
