  #1
Old July 8th, 2002, 02:24 AM
hulteen hulteen is offline
Default Will a different Stator Fit or Work on a 1974 Mercury 850
I have a 1974 Mercury 850-85HP motor Thunderbolt Ignition, It has a 2 wire Stator on it, and I was wondering if another stator would interchange with it? I have access to either a "red" stator for a 1987 75HP mercury, that is supposed to fit mercury, mariner, and force motors. also a stator from a 1992 50HP Force motor, and there are 2 others I could get that came off of 1983 Mercury Inline 6 Outboards, they all look very similar to mine but I can't tell exactly, they have more wires than my 2 yellow wire stator had, but I am assuming these extra wires are for triggering and can remain unused if I installed it on my motor assuming they would fit....are any of these stators interchangeable (universal) across the merc/mariner/force line, or are they all motor specific? I am looking to save money, and don't want to spend $200 for a new one when I could have a barely used one for about 15% of that. anyway thanks in advance for any help or advance.P.S. my motor has a distributor and breakerless ignition if that helps at all but my stator only has 2 wires......anyway, I'm rambling, I just wanted to be very specific....thanks.
  #2
Old July 8th, 2002, 02:25 AM
Default Re: Will a different Stator Fit or Work on a 1974 Mercury 850
I mean thanks in advance for advice.
  #3
Old July 8th, 2002, 07:30 AM
agefhx agefhx is offline
Whats wroung with the old one? Let me guess the wires are rotting? If so, this is what i did (i have the same motor). I took my old stator to my bench grinder, it has a grinding stone on it and a wire brush. I then carefully using the stone wheel ground the metal ring surrounding the 2 wires. Then using the wire wheel i followed the wires through the plastic coating, only taking out enough plastic to follow the wires down to where they are soldered to the coil. Then i resoldered new wires and filled in the gap with rtv, although i should have 5200 or something a little tougher. Good Eye protection is a must!!! What else you have to lose, besides getting a new stator anyway. I have 10 hours on the motor since i did this and seems to be working fine.
  #4
Old July 8th, 2002, 12:11 PM
Actually, yes, it was the rotting wires, and I did exactly what you did, and I soldered new wires but instead of RTV I used some epoxy. I'm sure it would work, but I wanted to replace it anyway, and there are a number of used ones for different motors I could get inexpensively.
  #5
Old July 10th, 2002, 06:40 AM
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1974 Johnson 85 hp Power head will one from a 69 work? TheOrigionalSteve-O Johnson & Evinrude Outboards 2 April 1st, 2005 07:20 AM
Will 150hp stator and trigger work on 125hp. nickntiff Force & Chrysler Outboards 0 January 9th, 2005 12:46 PM
Can you put the wrong stator on and make it work mikemartyo Johnson & Evinrude Outboards 10 October 1st, 2004 06:17 PM
stator for chyrsler 1974 60hp Gary Chandler Force & Chrysler Outboards 2 September 9th, 2003 09:55 AM
will my 1974 85hp v4 powerhead work on a 73 135hp tomwerdy Johnson & Evinrude Outboards 5 August 21st, 2003 06:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
