  #1
Old July 5th, 2002, 06:33 PM
cavitill cavitill is offline
Default Mercury 150 ob. No power out of hole when pulling a skier.
I have a 1988 Mercury 150 hp XR2 v6 ob. and its been rebuilt about 3 years ago, and it idles fine,and runs good at top end, its got good compression about 115 lbs all around, have went thru the carbs and cleaned needle valves, the plugs always seen slightly damp and dark in color,I ran a test on the trigger and stator according to the book, and where is calls for 5400 to 6200 olms on the stator I get 1650 on one and 1970 on the other, and where is calls for 1100-1400 olms for the trigger I get .755 olms and for a test between the red wire and ground and red/white wire and ground, on the stator it calls for 125-175 olms I get .055 on both, the boat seems to run fine when just running around but as soon as I try to pull a heaver skier on salom I can go around the lake at 5 mph and soon as he lets go Im gone. I have a 14 1/4x17 prop. Could the stator and trigger cause this?
  #2
Old July 4th, 2007, 04:23 PM
scottrbishop scottrbishop is offline
Default Re: Mercury 150 ob. No power out of hole when pulling a skier.
This sounds a lot like my problem. Did it end up being the stator and trigger?
  #3
Old July 5th, 2007, 10:06 AM
Chris1956 Chris1956 is offline
Cool Re: Mercury 150 ob. No power out of hole when pulling a skier.
You should try a prop with 2" less pitch. Sometimes a high load on the motor will prevent it from even revving up. It may be that your prop is a bit over optimum, which makes it acceptable for all but the most heavy loads (like your skiier).
Alternatively, he can learn to do a jump start or dock start!
  #4
Old July 5th, 2007, 10:12 AM
Texasmark's Avatar
Texasmark Texasmark is offline
Porting the prop helps too without affecting other boat performance. The ports allow you to develop your hole hp faster because it allows gases to flow across the blades allowing the prop to ventilate and spin up at higher rpm's faster.
I had one and loved it.
Mark
  #5
Old July 5th, 2007, 10:44 AM
j_martin j_martin is offline
That's a 2.0 litre engine. It needs to spin up to make horses. A vented prop would make a big difference. Prop pitch should be at the high RPM end for wot, or even a little lower.
For skiing, I use a High Five. On hammer down the engine spools up quickly, then the prop bites like it's got claws. Pops out of the hole like a shot. Even with a 150, I change props for anticipated load. Lower for skiing, or a heavy fishing partner.
hope it helps
John
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
I'm second! Pulling a skier gregtobin Water Skiing 4 March 19th, 2007 10:55 PM
Pulling flywheel--20 hp 1976 Merc, busted bolt in hole Motor Boater Bill Mercury & Mariner Outboards 4 February 8th, 2005 11:45 AM
Yamaha F115 pulling skier ? hear4128 Non-Repair Outboard Discussions 4 December 17th, 2004 06:19 PM
Evinrude 70 stalls when pulling skier out Jonathan Moore Johnson & Evinrude Outboards 5 July 29th, 2001 09:56 AM
motor not pulling out of the hole Jon Garner Johnson & Evinrude Outboards 2 June 22nd, 2001 07:21 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
