  #1
Old June 30th, 2002, 05:33 PM
Massey Massey is offline
Default How do I replace my timing belt on a 1976 Mercury 115?
I have taken my engine down from the top so far, and I've come across the fan belt that runs from a pulley on the top of my crank shaft under the flywheel to a pulley on the top of my distributor cap. I've looked in my manual and I can not for the life of me understand how to get this fan belt to go over the pulley under the flywheel??? I've removed as much of the engine as I can to get down to the pulley wheel itself, and I just can't remove anymore unless I'm talking about removing the entire crankshaft....I think? The belt is small, maybe 20 inches in length, and is broken, freyed, unuseable, have to get a new one. Can anyone tell me how I'm supposed to get this thing on there? Please help! Major
  #2
Old July 1st, 2002, 10:10 AM
Gold Bear Gold Bear is offline
Default Re: How do I replace my timing belt on a 1976 Mercury 115?
Major,You have to pull the flywheel. When the flywheel comes off you can see that the pulley is attached to the bottom side of the flywheel.To pull the flywheel you should use a flywheel puller - that you can buy from your Mercury dealer for about $30. First you might want to try gentle persuasion to see if the flywheel will come off easily.With the flywheel removed you can slip the new belt in place. You have to position the belt so the flywheel will drop in place while installing the belt at the same time. Try to hook the belt over the pulley as you drop it in place. Be patient, this can be a pain, just make sure you do not crush the belt.The top of the distributor has an arrow (under the top cover) that must be aligned with a point on the flywheel for correct timing. I hope you have a service manual that will show you how to accomplish this part. I do not know how your engine looks but mine (a 1972 model) has three vertical dots on the edge of the flywheel. When you install the belt the arrow will not point exactly straight at the marks - it must be slightly to CCW (counter clock-wise) of the three vertical marks. This accounts for directional rotation that tightens the belt slightly when the engine is running. If you install the belt one tooth off, the engine will run poorly.Good Luck, Gold Bear
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
850 mercury need help with belt timing Egriff Mercury & Mariner Outboards 5 May 15th, 2006 08:38 PM
Stator and Timing Belt - 1973 Mercury 150 hp (1500) natecollins Mercury & Mariner Outboards 6 June 17th, 2005 08:44 AM
1973 Mercury 150 hp (1500) stator and timing belt natecollins Mercury & Mariner Outboards 0 June 14th, 2005 03:30 AM
Mercury 175hp 1976 Timing couger Mercury & Mariner Outboards 0 September 3rd, 2004 07:07 PM
Timing and fuel for 1976 Mercury 1500 powertower Mercury & Mariner Outboards 5 August 9th, 2004 11:16 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
