  #1
Old June 24th, 2002, 02:16 PM
Terry Bitz Terry Bitz is offline
Default Mercury 6hp - Oil Leak From Prop Shaft Seals
I have a 2000 6hp Merc. Model 1006201WDI discovered some oil leaking from the prop. When I pulled it off, I noticed the oil seems to be leaking from around the outside edge of the prop shaft seal.My question is: How hard is it to replace the two seals? Do I have to pull the prop shaft off? Looks like Merc sells a seal kit for about $40. This will be the third time this motor has been in the shop for various repairs if I can't take care of it. Of course all repairs were out of warranty.Thanks
  #2
Old June 24th, 2002, 06:08 PM
RandyJ RandyJ is offline
Default Re: Mercury 6hp - Oil Leak From Prop Shaft Seals
From my couple of years of shade tree business the prop seals area a piece of cake. If you feel uncomfortable about it buy a manual. They aren't free but sure as heck beats paying $50-$100 per hour shop time.
  #3
Old June 25th, 2002, 02:10 AM
Bear Bear is offline
If oil is leaking there probably will be water in the oil too. What colour is the oil? Gray or white?It might be just unburned oil from the gas.Look at the colour first./Bear
  #4
Old June 25th, 2002, 02:51 PM
Thanks for the advice. I did not know there is a possibility for unburned oil to cause that. The oil I am seeing on the prop is mostly clean and light brown. Either way it's cheap and easy enough to drain the lower unit and take a look to see if the oil in there has a milky appearance. Thanks again.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lower unit oil seals on prop shaft 92 yamaha 200 whfish Yamaha & Suzuki Outboards 0 May 31st, 2005 06:32 AM
90 hp prop shaft seals fcryon Johnson & Evinrude Outboards 1 June 28th, 2004 05:37 PM
Prop Shaft Seals? springbok Johnson & Evinrude Outboards 4 January 19th, 2004 05:51 PM
cobra prop shaft seals tylerin Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 July 28th, 2003 05:38 AM
omc cobra prop shaft seals sea wolf Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 May 18th, 2003 02:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
