  #1
Old June 21st, 2002, 04:23 PM
mcknightr mcknightr is offline
Default mercury 115hp (water not pumping out of pee hole)
Is there a water pump on Mercury 115hp, can not find it listed in parts on this web site? No water is pumping out of pee hole.
  #2
Old June 21st, 2002, 05:30 PM
Down South Down South is offline
Default Re: mercury 115hp (water not pumping out of pee hole)
Your motor does have a water pump. If it hasn't been changed in a while it would be a good idea to replace it. No water coming out the pee hole could be no more than trash plugging it. I cleaned out one on a Merc just the other day. If you have muffs, put them on and crank the motor. Take a piece of small wire and run it in and out of the pee hole while the motors running with the muffs on it. Most of the time if it's trash blocking it, it will come out.Good Luck
  #3
Old June 21st, 2002, 08:41 PM
thank u down south I will try first thing in the a.m.mcknightr
  #4
Old June 21st, 2002, 09:01 PM
Oakgrove Boater Oakgrove Boater is offline
My mechanic friend once told me to blow(with an air hose or your mouth)into the tube at the outside of the motor while she is running and sometimes you can dislodge a piece of trash. Has worked for my 1986 90 hp Yamaha several times. "Hey it don't cost nothing so why not try"
  #5
Old June 22nd, 2002, 01:08 AM
Spidybot Spidybot is offline
mcknightr Hint: Use the search, look for 'impeller' or 'pee'.This subject is very often discussed on the board and you most certainly will find useful info.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard not pumping water mwrBoat Mercury & Mariner Outboards 3 June 23rd, 2009 01:11 AM
7.5 mercury (no water pumping) 308user Mercury & Mariner Outboards 7 April 23rd, 2007 11:25 AM
2002 MERCURY 125 NOT PUMPING WATER ROBERTSTELLJR Mercury & Mariner Outboards 3 June 19th, 2006 01:35 PM
water not pumping mercury burtinski Mercury & Mariner Outboards 1 April 15th, 2003 05:34 AM
Mercury 50 Overheating - No Water Pumping!! Jonathan Morley Mercury & Mariner Outboards 3 September 11th, 2002 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
