if i don't run my merc 150 for 3 - 4 weeks<br />the carbs and floats are stuck, even using<br />a stabilizer in my gas.<br />What is the best gas octine to use and the<br />best way to keep my engine and carbs running.
texasfish<br /><br />if you are having a problem with your floats sticking you have carb problems. It is time to tear the carbs apart and rebuild the the needle and seat are bad or going bad. <br /><br />good luck!<br />Nick
